The drop-down list for selecting the default voice is not working. It shows nothing.
Did you check the timeline for a message?
I was sure I had activated the Cloud Text-to-Speech API by following the instructions in the first post. It turned out the service wasn’t enabled, which is why the dropdown list wasn’t there. Your tip about checking the timeline told me what was wrong. Thanks.
Version 2.0.0 is in test now
The Google Services app has some new images and icons.
Google Services app image and icon
TTS Cloud image and icon
TTS Non-cloud image and icon
Translate image and icon
YouTube image and icon
Want to support development more?
Become a Patreon at Arie J. Godschalk | Membership | Patreon
The sourcecode and tickets for this app have been moved from BitBucket to GitHub:
Google Services v2.2.1 is available for testing
This update covers the user-facing changes from v2.0.4 through v2.2.1.
Install the test version · User manual and guides
This version is still being tested and has not yet been approved. It may not work as expected.
Google Maps routes
Save routes on Maps devices or calculate a one-off route in Advanced Flow. Get travel time, distance and estimated arrival for driving, public transit, walking or cycling. Refresh saved routes from the device or a Flow when needed.
Maps can use Homey’s location for either route endpoint and show estimated traffic delays for driving when Google provides the required estimates. Saved route readings and the last loaded route image are retained across app restarts. The latest update also gives Maps readings clearer names and includes Maps in the app imagery.
Announce directly on speakers
Google TTS, Google Cloud TTS and Google Translate can now announce directly on compatible Google Cast, Sonos and UPnP/DLNA speakers. Existing audio URL and translation Flow cards continue to work as before.
Choose Cloud voices per device
Choose and preview a Google Cloud TTS voice when pairing a device or later in Repair. Existing devices keep using the app-wide voice unless you select a device-specific one. A voice selected in a Flow card takes priority.
Clearer BLL support in Flow cards
Flow cards now identify text fields that support Better Logic Library coding.
See the Google Maps guide for setup and details.
Questions and examples are welcome below. Please report bugs or request features through GitHub Issues. Include your app and Homey software versions when reporting a problem.
Thanks for testing Google Services!
Google Services v3.0.0 is available for testing!
This update includes the changes since v2.2.1.
Speaker groups and volume controls
Create reusable speaker groups in the app settings, then select them in Flows or set one as a default output. Adjust and cap the volume for each speaker in a group.
For announcements to all discovered speakers, choose All speakers, All speakers (no TVs) or All speakers (no TVs or TV speakers).
Improved Sonos announcements
Sonos announcements play in order and restore the original groups and playback, including TV and line-in sources where supported. Announcement Flows can continue as soon as playback starts or wait until the speakers have finished.
Questions and feedback are welcome below. Please report bugs through GitHub Issues, including your app and Homey software versions.
Google Services v3.1.3 is available for testing!
This update includes v3.1.0 through v3.1.3, compared with v3.0.0.
Sonos announcements
Choose Play Separately for native announcements that can play over current audio in the selected rooms without regrouping. Choose Play in Sync when compatible rooms need to play together.
Announcements to an individual Sonos room can also start faster. If Homey cannot reach the room, it can find it again and retry without risking duplicate playback.
Improved speaker playback
Announcements on Windows and UPnP/DLNA speakers have improved playback restoration and completion detection. Speakers that become stuck now report a clearer error, and pending announcements are stopped.
Speaker lists in Pair, Repair and Saved groups also open faster and refresh in the background.
See when to leave
Set Arrive by and an optional Departure buffer on a Maps device to see Leave by, based on the latest route estimate.
Test Google services
Test Cloud Text-to-Speech, Translate, YouTube and Maps from app settings. Maps tests can check Routes and optional features separately.
