Hi..aim using my T90 Pro since over 2 Month and i dont had any issues regarding the login also i never had to login again…one time i could remember i must start the App in Homey new and it worked again! To be honest i had never test all functions in the Homey App, i create the zones in the Ecovacs App, made all settings, after successfully test run i teached the vacuum into the homey world and let them work …one simple Flows, for example Homey send over the Alexas the current status and informations to know what is going on during his work!
So basically i can recommend it but this is my own experience, keep in mind the login problem could also happen if you have an unstable network or big network with many access points…often i saw problems when devices must reconnect following a network outage or handover…
The 2FA issue when you login and verify, the add the Homey device, device inits and tries to login again (after msec). Also Homeassistand had this issue. and this is solved by using the auth token for further logins.
There was a bug in a previous version that skipped the token after a repair.
But all is fixed (afaik).
And anything happens again, I will check and hopefully fix it
Thanks. In a community, discussions often focus on potential problems, and judging by this thread, this one was no different. That’s why I wanted to ask specifically about the success stories and positive experiences.
First of all, thanks for your work on the Ecovacs app for Homey. My DEEBOT T30 Pro Omni has been running in my flows every day without problems.
Today I bought a second robot, a DEEBOT T90 Max Pro Omni (Care Kit), and added it to Homey through your app. Pairing completed, but right after adding it I got the following message:
[PASTE ERROR MESSAGE HERE]
What I see in Homey:
The device was created as “DEEBOT T90 MAX PRO OMNI Care Kit” (class: vacuumcleaner).
All capabilities are still empty: no battery level, charging state, work mode, suction power, water flow or error code. So it looks like the app does not receive any status from the robot.
The T30 Pro Omni on the same account still reports values (battery 100%, charging).
Details:
Model: DEEBOT T90 Max Pro Omni (Care Kit)
Robot firmware: 1.67.2 (latest according to the Ecovacs app)
The robot works normally in the official Ecovacs Home app
Is the T90 Max Pro Omni already supported, or does it need a new model or device class in the app? I’m happy to send diagnostics or test a beta version.
This testversion includes some first attempts to add maps for V2 devices. The device sould show a all maps in the camera view. In addition, a “current” map is shown with the current area. During cleaning the image should update every 5sec and draw the cleaning path.
This functionality is still in first alpha state. I happens that the map stops updating or only shows a part of the path. So still in progress…just try, but don’t rely on it too much.
This is an unofficial change to the Ecovacs module. It’s not sure if this will be added as PR.
@Linden85 I also added logging for “unknown devices”. Please install the test version and send me a dignostics report after the app is started.
Hello, thanks for the app. However, when I add my X12S, I just get the message “Device not available” and “‘XML’ based model identified (unsupported).” Will support for this be added to the app?
@RonnyW …well now its on what i ask few months ago…great thx for this futher development!
I load already your test version V1.3.1, Vakuum Model ist T90 Pro Omni with v1.103.0, Homey 26 with v13.5.3, if i can support wirh any kind of tests dont hesitate to contact me!
Yes, you can check if and when the current map gets updated with the path while cleaning.
If not, it would be good to get some statistics or correlations to a recurring reasong (like: path is only shown when Ecovacs app is also online on the phone). Just to get a feeling why MQTT updates are missing.
Well, 1 test scenario:
i started the vacuum cleaner out of the Homey App on my iPhone, Ecovacs App on Phone was off.
The vacuum cleaner moved to the first cleaning zone, the Floor plan will be updated every 5-6seconds, the map goes black for a short moment and come back with the current position additional i turned on the Ecovacs App and switched there also to the floor plan to see if this have any influence, no, same behavior if the Ecovacs App is off…
Next i stopped the vacuum cleaner inside the homey app and activate back to base station, it works but at this point the floor plan stops, no more positions updates also when the vacuum cleaner is back in base station, i switched on the Ecovacs App to see if the position will be updated in the homey App but nothing, in the Ecovacs App the vacuum cleaner shows the right position, Homey never updated now the home base position…not when you push the update symbol on the Homey App Floor Plan, not when you close/open Homey App, at this point i created a report and this picture below, it shows the last updated position on Homey side… report is - 04274bc3-0971-45da-b642-8da20b752810
Only way to update the position again in Homey is to reboot your Homey App in Homey, after the reboot the floor plan is black and will not updated again, only when i open the Ecovacs App the floor plan was updated with the correct vacuum cleaner position in Homey, see pic. below!
After this i create a second report - abe50b0f-43a0-48af-970e-f574db8b6cdb
