[APP][Pro] Divoom Pixoo64
Ok. I’ll check that out. Here is what i mean in a picture courtesy of GPT.
What I am perceiving is happening is the red, whereas maybe there is a way to process the small images on the Homey before uploading to the Divoom so that the green concept is happening instead. That would mean that the Homey would do some GIF-manipulation, but it should not be that heavy since the images are small. (Please ignore any “von oben” language in the picture. It was put there by GPT.)
I am thinking something like this:
If this is already happening or I am asking for something impossible I apologize.
That’s what the app does, but with a layer to support multiple frame counts gifs which your chat gpt analysis doesn’t take into account.
ok, digging into the issues there are 2 main problems :
  1. the Gif 24800 is 14 frame long, which isn’t playing well with the others (too long)
  2. the framerates of the gifs are very diffrent from each others which add to the trouble and your perception :
Icon Frames Delay FPS Composite
56798 2 1000 ms 1 fps 20
11373 1 200 ms 5 fps 2
58195 10 100 ms 10 fps 10
6354 1 100 ms 10 fps 1
20455 5 1000 ms 1 fps 50
24800 14 300 ms 3.33 fps 42
So it’s impossible to display them at the right speed with all their frames, even without 24800 as the Divoom can only support one speed (in some case with the frame duplication implemented it works, but not here).
I’ll release a test build with multiple options (each with caveat) to find the “least worst” rendering method.
New Test version 0.1.11
Added a Flow card to choose the animated sprite composition mode to fit your gifs and taste. It will apply to the current display so you can put it in your flow but also just test it by itself.
Awsome!
I’ll give it a try! Thanks!
just to be clear, none will be perfect, but one of them may look better for each case.
other than that you’ll have to design around the limitations.
I think that this is great! Everything is moving at least. :slight_smile:
The channel can be switched programmatically which is really nice, and I have coupled it to a remote which is working great. It would be very nice if the ability to switch channel was included as buttons in the interface.
Thank you.
I’ll check but worst case scenario you can use virtual devices to do that.
Version 0.2.0 is now available in TEST
main change : added icon-based device controls to view and switch channels.
0.2.1
26 juil. 2026
test
Added automatic IP recovery when a paired Pixoo64 changes its local address. New devices are named without their IP address.
I’m investigating a bug that seems to be related to a Dishwasher device clashing with the Pixoo64 app. If you feel like you experience some crash and use such a hardware (and related app, like Bosch Home Connect) let me know. I believe the bug is on Homey’s side but I’m looking into it also.
So far my ConnectLife (ASKO) works fine with the Divoom app.
