Ok did it! I didn’t know about this app.
I have device in my homey but there is no so devices in my broadlink app.
I saw in advance setting rc commands fron 1 to 30 but if i chabge name i have back an error
And u did learn the IR commands in the settings of the app?
Like push the button in the settings, go to advanced settings and rename the first command u learned?
Hi, just received my RM4 Mini.
Adding the device to homey was very easy, but if I tap the button to learn IR commands nothing happens.
The led on the RM4 Mini is not on, just nothing.
Am I doing something wrong?
I just received mine RM3 mini (broadlink) and try to installed on Homey with Broadlink app.
After many times to trying to add the RM3 mini with the ip adress to Homey got a message “unknown (5F36)”
No idea what goes wrong and after reading on the forum i found this app of Pieterv123
After i have installed this app you get a Broadlinkred app in Homey.
When i goes now to add app and i choise Broadlinkred you see RM3 mini.
I click on RM3 mini and install the ip adress and i got the RM3 mini on the Homey.
After this installation i installed the broadlink app on the mobile
I install the device and also add the appliances (TV, Setup box, Mediaplayer, etc…)
This is working oke on the mobile to control it with the broadlink app on the mobile.
Now i will try to make this also possible on Homey.
I goes in Homey to the device “RM3 mini red” settings and i see a list of 30 empty commando’s.
I try to touch on learn IR commando … push the button for a while but nothing happend?
Also try the touch the remote control of the TV while i pushing the button of learning IR commando but nothing happend?
How or what must i do to get the commando’s whats on the broadlink app of the mobile to get this on the Homey app “Broadlinkred”
What steps must i make or do maybe i have missing something ?
Who can helped me ?
Yes i was not read it correctly sorry so After i have installed the app “Broadlinkred” in Homey.
Then installed the “Broadlink” app (Broadlink - universal TV remote) on the mobile (playstore).
the installed of Broadlink goes as follow:
Hold the reset button 5s on your broadlink device until the (blue) light flashes
In the Broadlink app (iOS / Android) Go through the “Add Device” steps
When you reach the step to add the device to a room - quit the app
The last row is very important yes to close the app when you see add the device and join the room.
After this i select in Homey the device “RM3 mini red” and also in the advance settings i re-authenticate device on yes.
When i click now on the button of learn IR commando it works.
After a few days, weeks, I don’t know exactly, some commands don’t work anymore. Two gates control. I need to relearn the command.
Has anyone encountered the same problem?
I’ve looked at the community App Store and saw 2 versions of the app. Does the non red version of the community app work with the rmpro (rmpro3 I think)? Looking to update homey but I rely on the rmpro for some old fans and this app here doesn’t seem to be updated anymore.
