[APP][Pro] Apple TV & HomePod
It seems to fix the problem.
I disconnected the HomePod mini from my Apple TV as default speaker.
Selected my HomePod mini as airplay speaker to my Apple TV.
Now I can use my HomePod mini as airplay speaker again.
I don’t know if the problem was this application, but strangely it didn’t work when I installed this.
Thanks for the help @BasMilius !
@Tim_Smits1 Good to hear that it’s resolved! I don’t know if airplay in general has some kind of limit that was hit because if this app… Will do some more research in the future :slight_smile:
Strangely now I have some problems with my Apple TV.
I get the message:
Disconnected from Apple TV (Companion Link), reconnecting…
I restarted everything multiple times and tried to repeat the add device multiple times.
I even removed the remote in the Apple TV settings so it is not connected anymore.
Unfortunately with no succes.
90f8ccc4-a0d6-4aa7-960d-30906294c1bc
My Apple TV 4K often does not update its status correctly. As a result, it sometimes appears to still be on even though it is physically turned off. Occasionally, a red triangle icon is also shown.
What could be causing this behavior ?
@Tim_Smits1 Yeah that issue I experienced myself as well. I have a busy week this week, so the plan is to work on my Homey apps this weekend again. Hope that I find the root cause, both your and my own diagnostics report don’t say that much :frowning:
What you can try is to just restart the app itself, that fixes it on my sight for a few days.
@Remco_Dekker Weird, seems that the AirPlay connection is doing something funky. Can you send a diagnostics report if you experience it again?
Anyone have problem connecting more then one appletv ? I have 4, i can only connect 1.
@Marcus_Fasth @BasMilius
I have the same problem, i have 4 Appletv. When i added one i cant find the rest. And when i delete the one i can see all 4
Here is the diagnostic code.
565239b3-9663-4b9f-b103-a654f39f6003
The Apple TV has now started up, but the Apple TV app in Homey does not detect it. As a result, my Flows related to this automation are not working.
@Adam_Olsson Weird, does your phone for example detect all 4 of them? And what are the Apple TV’s called?
@Remco_Dekker Hmm, for some reason the app expects more data from the Apple TV and got stuck there. I’ll do some tests this this weekend to see if I can find something…
Did you check this?
Thanks Asterix ! It was already on this setting
Ok I manage to make the Apple TV show the code and when I input the code I get this error message I will live the photo of the message and the report number
report number
4a76304d-7e99-47e2-9fbe-9305f81ec4f8
I’m also getting the red exclamation mark now. When I restart the app, it finds/connects again, but this error message keeps appearing regularly. Therefore, I’m sharing the error code for this issue as well.
5cc5006a-a502-42d3-adef-a2fd3d8abf57
Feature requests (no clue if feasible)
  • expose the humidity and temperature sensor
  • Enable announcements via the intercom function
Would be nice
@Casi_22 @Remco_Dekker Thanks for the reports, looking at it tomorrow. I did some changes today that I’m testing in my own setup, it looks that the connections are more stable here, but we’ll see… Hope I have more information tomorrow.
@Nils_Kijkuit Unfortunately both are not possible through the protocols that I’m using. There is a todo for me to find out how to get the humidity and temperature sensor information, but that seems like a whole new reverse engineering project for me. Announcements are basically the same story.
Too bad. Maybe some day :slight_smile:
Thanks for all you’re work @BasMilius :flexed_biceps:t2:
