[APP][PRO] API Builder
API Builder
Create your custom endpoints using flows and GET/POST data to/from your Homey - perfect for that custom dashboard or external system.
App Store: Install API Builder
GUIDE: Android custom widget guide using API Builder
Getting started
Creating your first endpoint
To create an endpoint, create a “Request received”-trigger in the “When”-section. Select request type, GET or POST, and define the path to this endpoint, for example /temperature.
If you for example select POST and enter the path /temperature, your flow will trigger if you make a POST request to https://YOURUNIQUEID.itconnects.se/temperature. It will not trigger on a GET request to this URL.
A flow tag will also be created containing eventual request body data.
Responding to requests
To respond to the request with JSON data, you use the “Respond with JSON data”-action card in “Then”-section. Here you can build any valid JSON including tags. This will be send back to the requester.
Make sure you type valid JSON or it will fail!
Making a request
When requesting any endpoint, you also need to include your API key as a query parameter in the URL, for example https://YOURUNIQUEID.itconnects.se/temperature?api_key=ABCDEF123456.
Testing
We recommend using Postman when testing your endpoints. It can be downloaded for free here.
Demo flow
Here:
API Builder App for Homey | Homey
Hi @norenz,
This app looks promising! I would like to build an API to and from Homey in this way. The only thing I find a bit difficult is that this goes through an “unknown” server for me. Would it be possible to build this app locally? So the same functionality but via the local homey IP or the public Homey IP ([id].connect.athom.com). I think more will need this. Of course you buy a Homey to be as independent as possible. If you don’t like the idea here, no problem at all! Still, I hope you’ll consider it. The idea of this app is really good. If this app can run independently on homey with equal authorization (API Keys and maybe IP) then this app is great! I hope you will consider this. Thanks!
