[APP][Pro] Ajax Security System - Make Ajax alarms part of your smart home
I have the latest version but one of my hubs (I have two) is not connecting anymore. I have one main account, with tho houses. The first house works fine, the second one worked fine until the last update. Now the hub and all accessoires are not connected. Any help?
Both hubs are connected to the app, but all devices are not working. Any idea?
Could you send a full diagnostic report via DM (that’s the one you have to do via app settings → diagnostic (Diagnostiek) and then share via a sharing site (onedrive/iCloud/wetransfer etc.) so we can get to the bottom of this issue.
Cheers
Hi Mike, thanks again for all the work on this app!
I updated to 1.0.756 (public version) and tried once more to add my hub, but no luck yet. I get:
“Ajax authentication rejected by mobile gateway: invalid email or password”
Setup:
  • Login type: Ajax account / mobile app
  • App label: Ajax
  • Regular (non-PRO) admin account, no 2FA
  • The same email + password logs in fine in the regular Ajax app on my phone
Diagnostic report: dd28808e-6c0f-4e0a-91d5-b45f833e1f0f
I’ve been temporarily blocked by Ajax before after several attempts, so I’m holding off on more tries for now. Would you recommend switching to the test version, or is there something else I should check first? Happy to test whatever helps. :slightly_smiling_face:
I might have figured out the issue. It seems an old/incorrectly entered password could remain “stuck”. Uploading a version that should remove that restriction now (A while back I’ve made logging stricter, so incorrectly entered passwords wouldn’t flood Ajax servers)
Hi Mike
Im struggeling to have my Ajax Hub linked to the App, any chance you can advice.
I think its all in the HUB setup…
I got:
Homey Pro 2023 v. 13.5.4
App v. 1.0.761
Ajax Hub 2 Plus Jeweller , FW EU 2.45.117
Homey app just keep telling me to go to Ajax and configure the setup when i try to add device from Homey.
Rgds. Jan
So everything has to be setup on the Ajax end first, after that you can integrate into the smart home. If that is all done, then ill need a log to see what’s going on after you add the device.
Grts,
Mike
Hi Mike
Ok - I configured the Ajax Hub as you can see on attached pic. Then I tried to add new dev. from Homey but got a timeout msg.
Rgds Jan
Sorry Jan, I’m not sure what I’m looking at here? Best is to make a diagnostic log.
The setup should be fairly straightforward, just make sure the hub is installed on the ajax app, then either use SIA, Mobile login, Enterprise login depending on the homey the situation.
Hi Mike
:smiley:
Well I Think it all starts with trouble to have the app adapt my Ajax Hub.
I start in Homey with adding a device and selects Ajax, then I have the opportunity to
select between several Ajax devices, here I select the Hub. Then I go on and the app will connect
to my Ajax Hub and I get this screen and I don’t find any way from here :thinking:
Is the next step in the Homey app or in the Ajax app. Unfortunately I don’t see any way to configure or do any config in the Homey app. Hope you can advice :pensive_face:
Rgds. Jan
And the ajax app (not the homey one, the actual ajax one) is fully set up ? Also did you do those steps in homey?
Yes - been running for long time without Homey interface.
My first added screenshot was the modifications done to the Ajax app in order to have it use SIA
Did you do the steps that are described in the screenshot you send? (Ive included screenshots of doing those steps in my post)
These steps
