Ajax systems integration to complement home security
@Thomas_Thaulow
Thank you for this app.
I have installed your app, using the API. i can add devices. I have made four test flows: 1. start flow - arm Hub. 2. start flow disarm hub. This works well.
  1. when Hub is armed sent a push notification
  2. when hub is disarmed sent a push notification.
    when i test 3 or 4 by arming or disarming in the Ajax app, the notification comes slowly.
and in the hub icon in the homey app doesn’t seem to be up to date with the right status or history events.
Hi! Can you try an flow: start flow → and only if night mode is enabled → disable night mode?
My hub is working on 4 or 5g. IT works fine with the Ajax app, in homey its not. My test flows: when state is changed, give a notification are hours to late
Same here. When using the API the status is not correct, Relays don’t work, ghost commands are created, etc.
What integration type do you use?
Where can i find the settings? When i go to apps, Ajax, i only see, rapport and restart app, not settings.
Ah didn’t see that. Made this app a while ago and it has been working flawlessly for turning on/off the alarm automatically when I come home or leave home. I’ve updated it a bit today, but it’s mainly for my own use. Hope you get the app working perfectly for all users.
Im guessing this is a response to my test app, I did push an update today that should fix these problems
Is there anyone who can help me with a Proxy Server URL or an Ajax API Enterprise?
I am located in the Netherlands. My thanks would be greatly appreciated.
Does anyone have experience with the Ajax SmartLink? I read that it can be used to connect Ajax with Homey, curious if that actually works well in practice.
I’m new here so I can’t post two links, but you can also find a video on YouTube: “AJ-SmartLink voor integratie met Ajax Systems”
The homey apps that listed in this thread does the same without needing to buy a device for 189 euro.
I have been waiting for this also, great work!
Can someone help me with an api or proxy? I am located in The Netherlands!
Thanks!
Be careful with the proxy / api-key. With the proxy / api-key someone else can control your security system. So the proxy-server is a central station who can control lots of security systems and is direct a high security risk. If the server is hacked the security system can be turned off. I believe you can only trust this kind of server to a serious company. If Athom runs this kind of server the risk is less but their still be a risk. The best solution is to use SIA. With SIA the security system sends events to homey directly without any server in the middle.
if you aren’t aware of these risk don’t give someone control of you security system for an homey integration.
Stay safe an let the security system be secure!
Its true that a proxy can see all events going through it. However the Ajax Proxy I have made use of during testing started supporting encryption for not to long ago. The idea was to support the “bring your own proxy” as a temporarily solution until we could get a dedicated Homey proxy up and running. The only proxies setup now are as far as I know setup by a single security company in Sweden, and the proxy code is developed and maintained by a national technical director for a Ajax country.
I would ofcourse prefer not using a proxy, but its really the only way for “normal” users who do not have enterprise keys, to get more functionality outside arm/disarm.
Without telling to much, we do have a lot of great progress now, so I hope and believe we will have a more elegant solution very soon! In the meantime it might make sense to add a warning in the app about not trusting proxies you dont know.
Can you eleborate more because in the newest test version of your app you have removed the Enterprise API, which makes it useless for me…
The test version is mainly for testing the app, and not for endusers. So I do not recommend using the test version. The live app is not changed yet.
I am working on a major design change that would allow all users to make use of the API through a combination of a shared proxy for Homey users and SIA. This would give us the best of both worlds, follow Ajax´s recommendations and give us the most functionality we can technically use. Because all of the functionality then would work throgh the proxy, we will deprecate the use of your own Enterprise API, as this is mainly for security companies to monitor many hubs, and not for endusers. It should not change the amount of functionality for you, as we still use an Enterprise API, just not yours.
Great work so far. Installed it and it works with the SIA. I van see statuses etc.
I would love the arm/disarm option and usage of individual Ajax devises in my flows. I understand after reading this full thread I will need an enterprise API distributed from Ajax itself?
Cheers
What should I put as Proxy URL? Inserting just the ip of the hub does not work. Account ID is the Object ID under SIA? (I have a Hybrid Hub)
Any news on this?
Any news from Ajax? I think this integration is a game changer for Homey team.. could you share some update on release?
