Hi everyone,
I’ve built a Homey app for Narwal robot vacuums. It controls the robot directly over your local network, so no Narwal account is needed. If you prefer, you can switch to Cloud mode and sign in with your Narwal account instead (handy when the robot and Homey aren’t on the same network).
The app is waiting for Athom’s review, so for now it’s available as a test version only. I’m looking for testers!
This is an unofficial community app, not affiliated with Narwal.
Features
- Start, pause, resume and stop cleaning, return to dock, and locate the robot
- Live status: battery, charging, docked, cleaning area and time, current room, errors
- Fan speed: Quiet, Standard, Strong, Super Powerful, Ultra Powerful
- Room cleaning from Flows, with room names exactly as in the Narwal app
- Cleaning settings (mode, water level, mop strength, passes, route) and a “Clean with settings” Flow card for one-off cleans
- Flow triggers, conditions and actions for automations
- Map widget for your dashboards: the robot’s map in the Narwal app’s room colours, room names, the dock, and the robot’s live position and cleaning path while it works (light and dark theme)
- Local by default, optional Cloud mode, no telemetry
Supported models
| Model | Connection | Status |
| Narwal Flow 2 | Local + Cloud | Tested daily |
| Narwal Flow | Local + Cloud | Confirmed by owners |
| Narwal Flow Compact | Local + Cloud | Not tested yet |
| Narwal Freo 20 | Local + Cloud | Confirmed by owners |
| Narwal Freo 20 Edge | Local + Cloud | Reported working |
| Freo Z10 Ultra | Local + Cloud | Confirmed by owners |
| Freo Z10 Pro / Turbo | Local + Cloud | Confirmed by owners |
| Freo X10 Pro | Local + Cloud | Confirmed by owners |
| Freo Z Ultra | Local + Cloud | Not tested yet |
| Freo Pro | Local + Cloud | Not tested yet |
| Freo S | Local + Cloud | Not tested yet |
| Freo X Ultra | Cloud only | Not tested yet |
| Freo X Plus | Cloud only | Not tested yet |
| Freo Z10 | Cloud only | Not tested yet |
Cloud only models keep their local port closed, so they always connect through your Narwal account (sign in in the app settings first). Each model’s pairing screen also shows how it connects.
Not supported: the original Narwal Freo (2021), T10 / J1 / J2, China-only models and Narwal floor washers.
If you own one of the “not tested yet” models, I’d love to hear whether it works for you!
Getting started
- Install the test version: Narwal | Homey
- Make sure the robot is awake, then go to Devices → Add device → Narwal and pick your model.
- Choose your robot from the list of robots found on your network, or enter its IP address.
- Optional: add the Narwal Map widget to a dashboard.
For Cloud mode, open the app settings, choose Cloud and sign in with your Narwal account (emailed code or password; your password is never stored). Cloud replies are slower (around 20 to 30 seconds), because that’s how fast the Narwal cloud answers.
Once the app is approved, you’ll get the App Store version automatically. Your paired robots and settings stay as they are.
Coming next
- Tap rooms on the map widget to clean them
- Looking into the robot’s camera on the device page
Feedback and issues
Please post here, or open an issue on GitHub: Issues · TheBlackBush/narwal-homey-app · GitHub
When reporting a problem, it helps to mention your robot model, whether you use Local or Cloud mode, and what the app’s settings page shows under diagnostics.
Thanks for testing!
