Rfxcom
Read and writes to Rfxcom devices and easywave RX09 usb stick to communicate with rf 433 devices like oregon klika oregon and rf x10 (not x10 security protocol ) 868 devices like visonic and with faak rollershutters
it works with the following rf 433 and 868 intefaces
- rfxtrx 433 all models connected to a pi 3
- legacy rfxlan devices all models 433 and 868
- Eldat Easywave USB stick RX09 to control faak rollershutters connected to a pi 3
it implements the following devices
*Oregon
*X10
*visonic sensors
*faak rollershutters
12-11-2017 complete rewrite to sdk2
left app settings these are not evolved like the devices , made devices of rfxcom transceivers, receivers and transmitters
22-12-2017 first admission to github beta version rfxtrx receiving put off
x10 works on lan sending and receiving
TEMPHUM works
app still in design fase
30-12-2017 combined drivers lan rfxcom devices and rfxtrx devices in driver rfxcom
visonic sensor devices door and movement and contact are available and report their status
x10 ms13e on/off and dim works on lan and rfxtrx sending on/off commands possible rfxtrx and lan , dim and bright also on lan andrfxtrx
each RfxCom device can be stopped receiving an sending data via settings
16-02-2018 all visonic devices security are placed under the slave driver ,
for first inclusion of type of device in the slave driver which should include all devices in the future as class extended by master driver
added last read time sensors in settings device
made THB sensor work in oregon driver
added Eldat Rx09 Easywave usb stick which receives Easywave Rf on a pi 3 as virtual rfxcom device
to make the pi usbserial driver work with the Eldat Rx09 usbstick see
https://raspberrypi.stackexchange.com/questions/78908/eldat-easywave-usbserial-device-not-detected/79020#79020
to adapt the pi 3 for serial to net communication with Athom Homey
https://github.com/nattlip/pi.node.serial2net
added Faak rollershutter Easywave device working with the Eldat Rx09
27-02-2018 deleted temphum driver, incorperated it in overall oregon driver
added supprt for oregon temp , rain and uv devices, so functionality is same as orgeon app
added flow trigger for received X10 on off commands
23-08-2018 added new forum link
27-01-2019 made app Homey firmware V2 compliant, a lot changed in the pairing code V2
28-01-2019 fixed a bug in socketclient
3-02-2019 fixed that not more then one usb device could be reached on a Rapberry pi, now multiple connections are possible with pi,
or an ip in general (usefull in portforwarding)
15-03-2019 fixed two bugs which could led to crashes, receiving a somfy signal and adding remotes for somfys, somfy is not implemented in app ,
but rfxtrx receives the commands.
If you like the app, consider buying me a Homey Pro !
Copyright (c) 2019 Jilles Miedema
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the “Software”), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. Contact GitHub API Training Shop Blog About © 2016 GitHub, Inc. Terms Privacy Security Status Help
