control & read out your Zeekr from Homey Flows
A quick note up front
I built this as a proof of concept. I want to be upfront: I have no experience with coding or maintaining apps whatsoever — I put this together with AI assistance, step by step. It works on my own car.
So I’m mainly sharing it as inspiration: I really hope it shows what’s possible and motivates someone with real development experience to build a proper, maintained Zeekr app for Homey. If that’s you, please feel free to take any of this and run with it.
What I set out to do
The original idea that kicked this off:
“I want to turn an existing Android app — OpenZeekr, which gives full control over your Zeekr by logging in with your email — into a Homey app. My goal is to preheat my car and read it out through Homey flows.”
So: not a rewrite of the Android app, but a Homey app that talks to the same Zeekr cloud, so preheating and status read-out can run from Homey Flows.
What it does
A Zeekr car device with:
- Battery %, range, charging state + charging power (kW)
- Locked/unlocked, doors/trunk/windows open, interior & exterior temperature, odometer
- Automatic status polling (interval configurable, default 5 min)
Flow actions: start climate (preheat/cool with target temp + duration), defrost, seat heating/ventilation per seat, steering-wheel heating, start/stop charging, set charge limit, battery preconditioning, windows, tailgate, lights/horn, sentry mode, and “refresh status now”.
Flow triggers: charging started/stopped, cable connected/disconnected, climate on/off, range changed, status updated (battery/range/location), command failed.
Flow conditions: is charging, cable connected, climate on, battery above/below X %, range above/below X km.
Example flow: every weekday at 07:00, if the outside temperature is below 3 °C → start climate at 21 °C for 15 minutes.
How it works (and why it behaves)
- The cloud layer is ported from OpenZeekr (MIT) — the reverse-engineered account login, request signing, status read-out and remote-control command catalog — rewritten in JavaScript for the Homey Apps SDK (v3). The Bluetooth digital key of OpenZeekr is deliberately left out; it only works right next to the car and isn’t needed for cloud control.
- The two signing schemes (user-center login HMAC and the TSP gateway
X-SIGNATURE) were cross-checked byte-for-byte against the referencezeekr_ev_apiimplementation, so the requests are identical to what the stock app sends. - There are automated tests covering signing, VIN/password crypto, status parsing and the login flow, and the app validates at Homey’s strictest
publishlevel. - It talks to the EU Zeekr/Geely TSP cloud (other regions are present but unverified).
Requirements & important caveats
- Homey Pro (2023); install via the Homey CLI (it’s not in the App Store — see below).
- You supply your own app keys. No Zeekr secrets are shipped (same principle as OpenZeekr). You extract the six keys from the official OpenZeekr release APK with a small included tool — no root or Frida needed.
- One active session per account. The Zeekr cloud allows only one login at a time: logging in from Homey logs you out of the official Zeekr app, and vice-versa. Recommended: create a second Zeekr account, share your car to it from your main account, and use that second account in Homey — then the official app on your phone stays logged in.
- It’s a reverse-engineered, unofficial integration. Zeekr can change the API without notice, which would break it until someone patches it. No warranty, use at your own risk.
Install (short)
Get the code: GitHub - bullseye1977/Zeekr-Homey · GitHub (git clone, or Code → Download ZIP and unzip).
Get the APK: Release OpenZeekr 0.2.6 · borconi/openzeekr · GitHub
- Install Node.js 18+ and the Homey CLI (
npm install -g homey), thenhomey login. - In the app folder:
homey app install(installs straight onto your Homey — no Docker needed). - Extract your keys from your OpenZeekr APK:
node tools/extract-keys.js openzeekr-x.y.z.apk zeekr-keys.json - Homey app → Apps → Zeekr → Configure: enter email, password, region (EU) and paste the keys JSON → Save → Test login (should list your car).
- Devices → + → Zeekr → add your car.
Status
Logged in and verified on a real Homey Pro 2023 with a Zeekr 7X (EU): login works, the car is detected, status reads out, and commands (preheat/charging/etc.) run from flows. It’s a proof of concept — rough edges are expected.
Credits & license
Built entirely on the reverse-engineering work of OpenZeekr by borconi and the projects credited there. No Zeekr secrets are included — you provide your own from your own app install. MIT licensed.
[grid]
[/grid]
