Community effort ![]()
V6.0.0 for LANDROID compatible devices will be in test soon…
Code restructuring, changed number capabilities to measure_ and will remove old ones. This will BREAK flows that use battery voltage, battery temperature, bladeTime, gradient and inclination.
Please change flows to use the new standardised flows.
Added more capabilities.
Added more flowcards
Make distinction between wired, vision and vision cloud (RTK).
if issues, please open new issue on Issues · dudz40/issues-for-homey-apps · GitHub
I created one request for missing capabilities, however it seems that only you can assign labels for issues ;-(
Also I wonder, for some time already, the updates I’m getting from my Worx, they seems to be quite delayed, can’t you make poll interval configurable ? I know in the past there were rate limits, but now it seems it’s like 1 update per 50min or so ?
Need to check, but i think i have made this dynamic, e.g. when the mower is at its base it should have a long poll period, when it is mowing it will be frequent. Cannot look in code right now, but that was the plan…
Seems you are right - when it’s mowing, updates are more frequent, just checked, thank you.
There is still a rate-limit active, but will adapt the polling to more aggressive values in the next update.
@home every 10m, when mowing 1m.
Still had the old names in the repo. Fixed in 6.0.1
Can people with a Vision Cloud (RTK ) mower try the test version and check back in if any issues?
issus on Issues · dudz40/issues-for-homey-apps · GitHub please.
