Ultimate EMS v2.5.4
New: price-based steering for heat pump/airco/heater
Room thermostats can now optionally react to the dynamic electricity price too, alongside the existing “follow solar surplus” behavior. Turn on “Also steer on price” per device, and the setpoint nudges up during cheap hours and down during expensive/peak hours — on top of the solar offset, within your comfort band. Off by default.
New: two Flow cards for the boiler’s cheap-hours schedule
A trigger fires whenever the schedule is recalculated (with the scheduled hours as a token), and a condition lets you check whether a boiler is inside its scheduled hours right now — hook your own relay, smart plug or notification into the same schedule the EMS uses internally. (Thanks Brian for the request!)
New: “Set active vehicle” Flow action
If you already have a Flow that detects which car is plugged in, you can now feed that straight into the EMS instead of switching vehicles manually in the EV widget. (Thanks Mantlet!)
Fix: stuck device links, now visible
A removed/swapped device (EV charger, heat pump, battery, grid or PV meter) could leave a setting stuck on an empty placeholder — silently. This is now checked and repaired automatically on every startup, and the EV widget shows a clear error instead of quietly looking like “no EV configured.”
Fix: planning a trip in the EV widget actually updates the plan now
Previously, saving a trip didn’t properly trigger a recalculation, so the widget kept showing the old plan until the next scheduled refresh. Now it updates immediately (today + tomorrow) and also pushes your target charge level to the car’s own onboard limit, so it won’t refuse to go past a lower limit it had stored.
Fix: less log noise from an offline device
A boiler or PV inverter that became unreachable used to get retried every single minute, forever. Now it backs off to once every 30 minutes after a few failed attempts, with a clear message when it happens and when it’s resolved.
Moved
“Peak hours” now lives under “Grid & connection” instead of “Electric car.”
