[APP][Pro] Spacey Plan - Interactive Floor Plan Widget for Homey Dashboard
I’m not quite sure anymore, but I think we’ve had that before, then the font is even smaller. That’s why I’d rather not do that. But if you click on the device, the decimal places will be displayed. In my opinion, that should be enough​:man_tipping_hand:t2:
But if you give me a convincing reason why the decimal places must always be visible, then I’ll think again​:wink:
Are there any other cool features desired? :thinking:
@Asterix
Okay, I didn’t realize the font size shrinks in that case.
I often run into the issue where the temperature is, say, 21.5, but it displays as 22 degrees because it rounds up. Clicking on it does solve that, but for the tablet on the wall it is an extra step. I often check the temperatur, because my house likes to hold the heat in the summer. So thats why 0,5 degree could make a difference in my situation.
A feature where you could swipe left to move to the next room. Or numbers at the bottom of the floor plan—if you have 3 rooms, there would be 3 numbers, and pressing number 2, for example, would take you to room 2. But I’m not sure if that’s possible?
The most convincing reason i can give is not very good. I just like to see it when i walk past the wall mounted screen.
I just dont like to stop walking and bending over the closet to hit the screen.
I wil just keep using the enhanced device widget with a virtual device to keep the decimals in vieuw.
Wy are the decimals some sort of important to me, i have a farm and i use homey to check product tempertuur and product humidity and i also use homey to start and stop blowers to keep the product in the right condition.
I’m aware homey hase no redundance so i wil also check time by time with manuly with analog devices.
But it just make’s live easy to have some more data(insights) from homey and al of the easy widgets to see things fast.
@Asterix
I am customizing the floor plan with my own custom-designed icons.
However, I believe a bug has been introduced since the last update.
I disabled the icon settings under “color select” so that the icon wouldn’t be visible on the floor plan.
But when I click on a light on the floor plan, it turns on; yet, clicking it again to turn it off doesn’t work.
If I close the Homey app and reopen it, I am able to turn the device off. In other words, I can only turn the light off after reloading the floor plan.
When I make the icons visible using the color switcher, I am able to turn the light on and off.
This used to work before the update.
Diagnostic report code: 6abafec6-138f-4ba9-8799-295ea8878fc0
Hi all,
@Ludvig @Rembo038 @qawsedrf57
A batch of fixes and new stuff, submitted to Ludvig just now:
Fixes:
  • Temperature on the floor plan now shows one decimal place (e.g. “21.5°C”) instead of rounding to whole degrees — requested by @qawsedrf57 and @Rembo038
  • Found and fixed a second spot with the same icon tap-through bug as before: this time it hit devices whose icon is hidden AND whose state changes live (lights, locks, sensors, speakers, blinds) — tapping could stop working again after the first state change. Thanks @Rembo038 for reporting
New:
  • Speaker: added a mute button (long-press panel), plus a small red badge on the icon itself so you can see at a glance that it’s muted without opening the panel
  • Washer/dryer status support (tested with V-ZUG) — shows status, program, and remaining time on the floor plan
  • Lawn mower support (tested with a ViAX 250) — status, battery, and a control panel (start/pause/resume/stop/dock/maintenance point), with a red highlight if there’s an error
PR: Add temperature decimals, mute mute-badge, appliance/lawnmower support, fix icon tap-through regression in live updates · Pull Request #8 · ludvigaldrin/com.svipler.app.spaceyplan · GitHub
Not doing (for now): @Rembo038’s idea of swiping between rooms/floors, or numbered buttons at the bottom. It’s a good idea, but a bigger piece of work than the rest of this batch — we’re currently leaning toward solving it differently anyway, via multiple Homey dashboard pages rather than a swipe gesture inside the widget itself. Parking it for a future round.
As always, please wait for Ludvig to merge and publish before testing — I’ll post here once it’s live.
Great thanks i can’t wait til it’s online
Its up up and away
You do not need to bump the version. Its better I do it with the publish script here.
Thanks for the update, it works and looks perfect now with the one decimal!
WoW, looks very cool :star_struck::ok_hand:t4:
Now Im starting to get back on track here in my new house. And is starting to get displays upp. Running Shelly Displays and found a nice app Shelly Wall Display Dashboard | Homey that can trick a dashboard to be like a Home assistant. So one can use Displays that support home assistant to instead run a dashboard. So what I started to think cant i like merge these apps functionality together. so we have spacey plan but then add support for Home assistant dashboards. That means we can make smarter dashboards but still use Homey as the plattform. So i want to add a dashboard builder and homeassistant support. Just some playingaround here.
The decimals are a great upgrade!
One more smal detail, i use a themostat for the hottube but the higest temp i can set with the widget is 30 degrees that is a little bit cold. Is it posible to make the setpoint to go to 38 ore 40?
Greatings a very happy user
I have been using this APP for the past few weeks now and I really appreciate the APP and find it very useful.
Recently, I created a floor plan displaying the temperature and humidity conditions in the different rooms. By default, the plan shows only the temperature values. I was wondering whether it would be possible to display both the temperature and humidity values simultaneously on the plan.
I am aware that by clicking on a displayed value, it is possible to view the other parameter. However, it would be much more convenient to have both temperature and humidity visible at the same time. Is it possible to have both values displayed?
Hi Carole,
For me, the temperature indicator with a digit is already taking up too much space:
So, in case your request is being honoured, I hope it will be added as an optional setting :wink::smiling_face:
Hi Carole
Having both displayed will rather be impossible. But I will see what can be done and is also easy and understandable to operate.
How is the performance on the Shelly wall displays?
I’ve read online that Homey dashboards don’t run very fast on the Shelly displays.
Hi @Asterix @Ludvig
Is it possible to add meter_power to the supported capabilities in a future update?
Usecase:
I have the generated solar power shown, and I’d very much like to show todays generated energy as well
Thanks
Hi! The thermostat setpoint range now goes up to 40 °C (5–40 °C in 0.5 steps). It’s in pull request #9 and will be available once Ludvig merges and publishes it.
Hi! Inverter values are supported in PR #9: meter_* capabilities (e.g. daily yield in kWh) and sub-capabilities such as grid active power and PV1/PV2, plus voltage, current and frequency, with units, icons and live updates. I tested this with a Huawei SUN2000 (Modbus). It will be available once Ludvig merges and publishes it.
Hi! Showing both values on one icon would be too crowded, so in PR #9 sensors with temperature and humidity offer three entries in the editor: the combined one (as before), temperature only, and humidity only. You can place them separately wherever you like. It will be available once Ludvig merges and publishes it.
Its pushed and merged. I have now also started planing for my new dashboard system that i want to add to this. To add HomeAssistant dashboard functionality. so its preparing for this moving some stuff around. Did some short tests and it looks like its working. But please make sure you have the latest before building since some things have moved.
