It`s here
The text is adapted in the next test - version, so you should understand it ![]()
=> “Toggle off to hide the icon…”
I tried it. Did set it to of. Set the color to blank/ white. The Thermometer is still there in black. Did even restart the app. Deleted the „all - color select“. Added it. The Thermometer is still visible above the badge.
Tried all this a few times. Just tried changing the settings via iPad. The one I tested worked!? Will investigate and keep you posted.
Your latest PR is up live now. Love how active you are. Keep up the good work.
Positioning works now. Hiding of the icon works.
Can you have a look at the positioning issue. The icons in the widget are still a bit off the position I put them.
Can you give me a concrete example and possibly capture it pictorially?
Do you do it in the web app or in the mobile app?
If on the web, which browser do you use?
If with mobile, iOS or Android?
Thanks for the app updates, great work!
I want to display the luminance (lux) from my motion sensor on the floor plan. However, I keep getting a motion notification in the top-left corner of the floor plan; is it possible to disable that notification? It overlaps another button on the floor plan, and I’m only interested in the lux value shown in the bottom-right corner.
Did you remove the (Contact) setting of the device and still get the alarm notification?
@SingKT In the Spacey Plan i dont see that setting.
I only added the luminance, so its strange i get motion alerts in the floorplan.
Tested it with a door sensor. Correct even with the motion capability removed a motion alarm is shown when triggered
I noticed when hidding the icon there is no popup when tapping on the value. Is that intentionaly?
@SingKT Good catch, that wasn’t intentional — it was a side effect of how the icon gets hidden (removed from the layout entirely, taking its tap target with it). Fixed now: the icon stays invisible but tappable. Also fixed the room-status badge picking up unrelated alarms from a device when only a different capability was placed on the floor.
Hi @SingKT,
Regarding the position mismatch between edit view and widget you noticed (the “How to remove?” screenshot) — I dug into the positioning code on both the edit page and the widget, and they use the exact same anchor math (top-left corner, no center offset difference between the two). So it doesn’t look like a bug in how positions are calculated.
Since you mentioned this is iPad and Android specific and you’re still checking on Web — that’s a useful data point. If it turns out fine on Web, it would point to a rendering quirk specific to Homey’s mobile app (e.g. how it scales/renders widgets on iOS/Android) rather than something in Spacey Plan itself.
Could you let me know how it looks on Web once you’ve had a chance to check? That’ll help me figure out where to actually look next, rather than guessing. If it turns out it’s not a Web-only thing, a screenshot with the exact offset (and ideally screen size/Homey app version) would help a lot too.
Thanks for testing this so thoroughly!
Thank you for your donation ![]()
By the way, Ludvig was so friendly and added my PayPal link in his first post ![]()
If you press for instance on a temperature sensor in the floorplan, it opens 2 times.
So if you want to close it, you have to press 2 times the “X”.
In the images below you wil see that on the first image the background is darker than on the second image. That is because on the second image i allready closed the temperature sensor once and the background becomes less dark. After the second tap op “X” the temperature sensor closes.
Doesn’t happen with me
