@Gruijter Pull request sent your way for the swedish translation
Many Thx @Teddy ![]()
You are now forever named as contributor to the app: Kia and Hyundai App for Homey | Homey
If anyone else wants his/her name immortalized, just translate the app to your local language ![]()
Installed 2.7.4. everything seam to look like it should.
// Teddy
Thx 4 reporting. Kia and Hyundai changed something on their servers. Community is working on itâŚ
Looks like the app now just keeps crashing and restarting. I can not do anything atm. I have not yet tried to restart homey itself.
It is not caused by Homey or the app. It is the Kia/Hyundai server that is causing the issue. As said the dev community is working on it.
I tried a Homey reboot. Unfortunately no success. Weâll have to wait for more information from Gruijter.
Update: the dev community has been working hard all day on this. It seems they reverse engineered a possible solution. It now needs to be implemented in the library I use. And then I need to implement that library in the Homey app.
If there is news I will let you all know here.
Yes, here too. The solution is mostly happening in the cloud. I need to check though if the current cloud part is good enough for my current Homey app, or that it will cause intermittant problems that require a Homey app update.
So pls let me know when (and how often) it stops working again.
Not working at all today (Hyundai Kona). Stopped working today/yesterday, no luck even when restarting appâŚ
[2022-02-07 18:52:32] e[31merrore[39m: @EuropeController.login: sign in with EuropeanBrandAuthStrategy failed with error Error: @EuropeanBrandAuthStrategy.login: Cannot find the argument userId in https://eu-account.hyundai.com/auth/realms/euhyundaiidm/login-actions/authenticate?
Yeah, stopped working again for me also. It does come up again after some hours, but I am pretty sure it will fail again on and off.
So more work needed
Thanks you for using your time on this
Looks like the app was able to get a server update around 20.00 today.
Doing any sort of manual commands doesnât seem to work though.
Can I confirm, connection was lost again.
Hello, I tried today register device/car again, because it stoped working and I am getting this error:
Could you please take a look on it?
Thank you
Did you not read the above posts before posting your own?
I was looking for solution here and didn´t find it. After I posted, I saw similar posts. I didn´t see them before
No problemđ. Work is still ongoing to fix the present new issue. I have good hope to release a fixed version tonight.
