Can you add a flowcard:
“IF Apple TV plays on profile …”
source: Profielen toevoegen en beheren in de Apple TV-app - Apple Support (NL)
Is this supported in the AppleTV API?
Sorry for the late reply, still not working? How is your HomePod connected to the network and how is your Homey connected?
Unfortunately, no, I can only fetch the available users and send a switch to user command but I cannot see which profile is currently active. At least, not in the current version of my apple protocols library, maybe something changed in iOS/iPadOS/tvOS 27.
Homepod on Wifi network, Homey wired connection but same network.
adding the device is still not possible.
Two releases went into this one, 0.14.0 and 0.14.1.
I’ve been using your app for nearly a year now. I have the latest app version 1.18.0. I have the latest Apple 4K box with ethernet connecter. I have TVoS 27.0. So, I’m all up to date. My problem pre-existed to earlier versions, so, I don’t have a smoking gun. If the ATV box is streaming something, e.g. YouTube or Amazon Prime, your app and Homey show what’s streaming. But, if the ATV is idle and just showing the screensaver, then the ap shows the device as unavailable. Should I drop the device and then re-add? Is there a problem on the ATV side, like permissions?
@Don_Brown Hmm… That’s weird, could you send a diagnostics report and give me the ID? Please restart the app first, then let something play and let the screensaver appear, when the device becomes unavailable send the report. Thanks!
Hello Bas,
Thanks for the quick reply. I’ve put off responding while trying to replicate the problem after a couple of changes.
@Don_Brown Great to hear! Let me know if it goes sideways after a while ![]()
Hello. I have TVOS 27.0 and ver 1.9.0 of this app installed. I am finding that my Apple TV is often showing as “No Response.” It is the only device I have configured in this app. It is ethernet connected as is my Homey Pro Mini. Restarting the app does not fix the problem. I cannot figure out what does fix it, because sometime is comes bback and works. I just cannot find the cause of it staartoing to work or the cause of it when it stops working. Just in case it helps, I generated a diagnostic report while it is not responding. It is 0bfde485-3529-4c35-ae1e-d65e0052e197 n
I am getting this error “Cannot read properties of undefined (reading ‘send’)” when I try sto start my apple tv
Hi Bas,
First of all, thanks for the Apple TV & HomePod app, it works really well when the Apple TV is in use.
I’m seeing one issue: as soon as my Apple TV goes into standby, the device in Homey keeps flipping between “unavailable” and available, roughly every 30-40 seconds. As soon as I wake the Apple TV, it’s stable again.
What I’ve checked so far:
So it looks like the Apple TV closes the connection periodically while in standby, and the app reconnects each time, marking the device unavailable in between.
Would it be possible to treat this as “standby” instead of “unavailable”, or to delay marking the device unavailable for a short while? That would also prevent flows that react to the device becoming unavailable from firing every 30 seconds.
Happy to provide logs or test a build if that helps.
Thanks!
Reinier
Hello, I’m having trouble with my Apple TV in Homey. The device “Salón Chechi Hause” still shows “No response”. It is on the same Wi-Fi network, AirPlay is enabled, and access is set to “Same Network”. The Apple TV & HomePod app is version 1.9.0. I restarted both the app and the Apple TV, but the issue remains. Homey shows the Apple TV as powered on, but the app information and remote controls are unavailable. Launching the Acuario app did not work. Diagnostic report: d3b946d1-1494-4810-81c0-06d6e8708478.
Lots of problems lately, not only with the Apple TV that’s on tvOS 27. Most of the time showing ‘No reaction’. I didn’t change a thing…
I own a few of the new home pod minis 2, and they don’t show up to add them as new devices, any plan on supporting those?
edit: I opened a PR with the help of Claude to allow for the new home pod minis. Here’s the PR: fix(homepod-mini): list the HomePod mini 2 during pairing by jcmartinezdev · Pull Request #56 · basmilius/homey-apple · GitHub
@jcmartinezdev Soon ![]()
@everyone: I’m almost done with a big non-homey project, so more time for my Homey-apps after that. I have a lot for a next release, in all of them. Appreciate the patience.
Hi everyone! I’m back working on the Apple TV & HomePod app. The reason that it took a while was that I had some other projects, but also that I had to wait on the new Apple TV and HomePod Mini.
There are some changes on the airplay protocol required, but I’m happy to say that I got it working. I just have to run some tests, let it run for a day, check HomePod Mini as well and then I’m going to release a new update to the Homey app.
I’m aiming to submit the update on Sunday, so it should be available somewhere next week.
Note: You can add the new Apple TV and HomePod Mini to the current version of my app, it adds and pairs correctly, but now playing information is not there.
I went crazy and did everything already, the app is submitted for review and will hopefully be available for everyone somewhere next week. Meanwhile, testers can already upgrade to the new release. A lot went into this release. The feature I’m most excited about is that we can finally play url’s on an Apple TV! ![]()
