[APP][Pro] Android TV - Take control of your TV experience
That’s just to make your own device. (Not needed) go ahead straight in your flow, go to WHEN device capabilities, choose the availability card.
Just tested and it works, thank you!
No problem! Happy to help! :grin:
Every time I try to add Leap S3 Pro Android TV I get taken back to the device selection screen after entering the pairing code.
Additional observations:
Scanning takes long
To rescan I have to open the Android TV App again. Adding doesn’t work a second time
Sometimes it doesn’t find my Leap S3 Pro at all
I cannot add my tv. I install the app on Homey, add the TV, het the paring code on my tv screen, enter it in the Homey app, and i get taken back to the add device screen, nothing happened. When trying again i can’t add the specific TV no more and need to delete the Android TV app from Homey and install again to retrospect. But with the exact same results.
Seems to be the same issue as @Bisch …
Edit: the device suddenly appeared. But with an error. When repairing it works, until i switch the device off, than is immediately unreachable again until I turn it back on again (using the normal remote) and repairing again…
I installed the Android TV app manually from GitHub. The app detects my TCL (Google TV), and as soon as I enter the code on the screen, the message “Unknown device successfully connected” appears on the TV screen. Then nothing happens, and the Homey app displays the message “Timeout after 30000ms.” Then it switches back to entering the PIN code, and so on. It’s impossible to add the device.
Hello.
Is it possible to add support for the new Formuler Z12 Ultra so it can be added in homey?
I think that won’t work as it is not running Android TV but regular Android, right?
Runs the same as Z11 Pro Max, which is no problem for your app to find, and im using my Z11 Pro MAX with your app without issues.
It’s not my app. I just searched what OS it is using.
Hmm.
So okay, I did a little bit of research on this issue with the Z12 Ultra, and here’s the results..
Picture # 1. Shows the current search results when trying to add the Z12
It finds all the cast devices you can’t use with this app, but no Z12.
Picture #2 and #3. Shows what a free random app from Play Store finds instantly upon opening the first time, and then the connected remote.
Picture #4 and #5. Shows another random and free app from Play Store and what it found instantly upon first run.
It seems to me that its NOT to do with the Formuler Z12, but this app herr in Homey, and it would be tremendously appreciated if someone could figure out how to make Homey find and add the Z12 Ultra through this app.
Oh, by the way, I actually like this app and I use it every single day to aid me and its this precis reason why I’m looking for help.
In this case I would download the app from Github (if available) and inspect the configuration files. There must be something that clarifies why one Formuler device can be added and another cannot be added.
I don’t own a Formuler Z12, but asked Gemini: Does a Formuler Z12 run Android TV or Google TV or regular Android tailored to run on TV?
And this is the response:
The Formuler Z12 runs regular Android (AOSP) that has been custom-tailored by Formuler to work on a TV.
It does not run official Android TV or Google TV.
Instead, Formuler uses a standard mobile/tablet baseline of Android 12 and overlays it with their own proprietary, ad-free custom launcher and their dedicated IPTV platform (MYTVOnline3).
Why this distinction matters:
  • App Store: While it includes the Google Play Store, the device is not officially certified as an Android TV device. Because of this, certain TV-optimized apps (like official Netflix or Prime Video in full 4K) may require using Formuler’s alternative market or sideloading, though it does support Widevine L1 for high-definition streaming.
  • Interface: You won’t see the standard Google TV or Android TV home screen interface with Google’s forced recommendations. Instead, you get a clean, highly customizable layout designed specifically for Formuler’s hardware and remote controls.
(Note: The only exception in Formuler’s lineup that officially runs the certified Android TV operating system is the Formuler GTV).
Hi everyone!
The device kept going unavailable on me, so I dug into it with the help of Claude Code and put together a fix:
In my case the trigger was a Flow I have that restarts Homey every night, if the TV happened to be off at that moment, the device never came back. I’ve been running the fix for over two weeks now without having to re-pair once: the device becomes available on its own as soon as the TV is back on the local network, and the connection is a lot more stable overall.
It may well fix the reconnect / device-unavailable problems others have reported in this thread too, though I can’t confirm that, it would be good to hear from anyone who tries it.
Recently I bought a Xiaomi TV with Google TV on it and I also see the TV being unavailable after swtiching it off. After restarting this app it is available again, but sometimes even without restarting the app it is available again. It seems that it is polling and just as it polls it doesn’t respond or something like that.
It seems to be hit or miss.
Hi.
The Z12 runs Android12, and the Z11 runs Android11. There´s no other difference and the Z11 is found by this app, and runs perfectly. I also have a GTV and you are correct, that runs Android TV, which is different from the newer ones. And all of them are using Android TV Rem,ote Service, and on the Z12 the Remote Service is running Version 6.9.9068221247, so there should be no reason at all for Android App in Homey for not to find it.
Hi everyone,
I’m having some trouble getting the app selection feature to work and would appreciate some guidance.
My setup:
  • TV: TCL 75C9K
  • App: Android TV (latest version)
I’ve verified that all the basic functionality works perfectly (on/off, mute, volume control, play/pause, and other standard buttons).
However, I cannot get the app selection to work at all. I created a flow with the appropriate “Then” card, selected an app from the dropdown list (e.g., Netflix or Amazon Prime), but when I trigger the flow… nothing happens. The TV simply does not switch to the requested application.
Does anyone have any ideas on why this might be happening or what I might be missing?
Thanks in advance!
None of the apps work? Please try some other apps as well. Opening apps through this app is somewhat hit or miss.
I use navigation to open apps
Hi Rudi,
I’ve tried with different apps that I’m subscribed to (Amazon Prime, Disney+, Netflix, HBO, Spotify, etc.), always selecting them from the dropdown list… and nothing happens.
To test this, I created the following basic flow, but none of them load. However, the rest of the functions do seem to work perfectly.
Am I missing something? Any solutions or workarounds?
Thanks in advance!
I have the same problem here with my KPN tv tuner that is a android tv box. It doesn’t start the app like youtube or disney+. What it does do is light up the tv to white for a few milliseconds.
It might be that KPN blocks specific features for this app to function properly, or it doesn’t work correctly because of their custom launcher.
