[APP][Pro] Advanced Virtual Device (Device Capabilities App) with Unique Text Status Indicator
I have a weird case. When I repair my AVD it says number field 10 and up are empty but the tools show the fields are there. I restarted DC app already.
Open repair and send me a diagnostic?
And perhaps PM me the TEF?
Fixed in the new Test version.
Also, Athom finally has removed ownerID from flowcards. This however generated an error when importing TEFs for flows.
This has now been resolved and TEF import (AVD and Flows) all work fully correct again :smiley:
Hi Arie,
I try to create a new AVD and after creating I can not create fields in the AVD. There is nothing below “Velden Sorteren”. I tried with 3.0.1 as well as the test version. Even if I import one of the examples, I can edit the example, however after saving and re-opening the AVD is empty.
This is both from the iOS mobile app as well as the Web interface
I can edit my existing AVD’s like normal, so it looks like creating the AVD is incomplete?.
Any clues? I don’t understand…
I can confirm the above. Same here:
I am on test version 3.0.1.
Okay, ill have a look tomorrow.
@Frans_Vos and @SunBeech
Thanks, enjoy your evening!
@Frans_Vos en @SunBeech and others,
The issue has been resolved and the new version (3.0.2) is already live.
My bad.
On of the things i did with version 3.0.0 was a huge clean up.
When i created the AVD about 4 years ago, it first used the Settings page of the device (instead of a custom Repair screen). In that settingscreen you could choose each field 10 times.
But because i wanted so much the Setting screen could not provide, i build a fully custom screen.
However, to keep already made AVDs working, i build a “transform” part into the AVD.
Those parts have finally been removed with version 3.0.0 to clean up quite some program-lines.
But :sweat_smile: those lines got activated if the new “custom” settings didn’t exists. Which is the case for all new AVDs. And in those lines, the new Settings were created (empty, but still created).
Without that (single) line, having a empty AVD creates errors.
So, extremly easy fix, and i have created a empty AVD in my test folder so that if anything like this happends again, ill get an error while developing.
My appologis for the bug and have fun sorting your fields :face_with_hand_over_mouth:
N.b. When you change Button1, all buttons below it are re-ordered in the sequence of their number. This is because the button1 is “special” (or at least some ShowAs options require button1 to be the first button). In a next version ill put an info-text at button one so users will know this.
Thanks for the quick fix!
Field configuration is available again when creating a new AVD :+1:.
Good morning Arie,
Thanks for such a fast solution. It works like a charm (again)!
Keep up the good work and have a nice day.:smiley:
Hi Arie,
I seem to have encountered something else, which is strange to me…
I try to make an AVD controlling 4 dimmable lights; more or less as in your template, called Lampgroep Woonkamer.
I have the buttons from the “5 lamps”-template where the OnOff button toggles the AVD. But I do not have the Then-flowcards to turn the AVD “on”(Zet Aan) or “off”(Zet Uit) that I have in other AVD’s. How can I change the AVD to get these? I do not see the difference with other AVD’s I created.
And, depending on wether I have Button 1(OnOff) on the Button tab or its own tab renames the other buttons to their own names or Ja/Nee
Further more when I set the class (Apparaatklasse) to Lamp, something strange happens.
The status on the bottom of the tile acts as a lamp, and on the web interface the tile grayes out and the status goes to Off (Uit) when the tile is switched off with the On/Off button. However in the iOS Homey App the tile grayes out but the status only changes the percentage to “:yellow_circle: Aan - 0 %”.
See below screenshots with different statusses.
Well, first of: each AVD has its own custom set field to x flowcards, in this case, you could use the set button to yes/no .
The reason you dont see the default homey flowcards: Turn On and Turn off, is because they only are shown when you have a real On/Off button.
Turn this checkbox on and you will see those default flowcards.
(You can only check that box for each unique ShowAs field).
Yes, changing the Button 1 makes that all other buttons are recreated. However, that the names go wrong is a bug. Could you PM me this bug and i hope i can fix it asap.
Okay, well, i know there is a setting for a light that when 0% it will also toggle the on/off. I guess i might need to implement that in the AVD settings.
However, the fact that its behavior is different on iOS (and for me on android it works like the webapp) to me means its a homey “bug”. You should contact them.
(And not sure what changed, but i cannot select or any status indicators anymore if the class is ‘other’)
Thanks Arie for your patience,
I love the app but sometimes get lost in the number of possibilities and settings… I turned on the mentioned box and directly I got the flow cards :slight_smile:
The PM is on its way…
Probably the status of the lamp is a memory thing, when the AVD is switched off from the “Snelle actie”, the status is not updated and when I open the tile afterwards I see that the slider is still in the last setting. A second after opening the tile all is set as supposed (even if I wait for more than a minute before opening the tile)
I’ll look into that and contact Athom if necessary.
I know, i plan on rewriting a complete manual on the AVD topic i have. But i first wanna fix some functionalities, clean up “old crap”, make custom lists and functions exportable in TEFs, make reflectionfields changable during import (just like when you import flows right now) and i guess then ill have time for the manual :sweat_smile:
But first, a widget for Better Logic Library :sweat_smile::face_with_hand_over_mouth::wink:
This bug is resolved in 3.0.3, its live now.
Great. Thanks again Arie
Hi all, anyone experiencing issues with changing/adding capabilities? It’s been ages that I had to change something, but just noticed the capability fields are not available any longer when trying to ‘repair’ the device. Probably I’m overlooking something stupid, if you can point it out that would help :p!
Which app version is installed?
Please make sure to keep it updated.
Please update the Better Logic Library (or at least restart it) and let me know if this solves the issue?
For anyone having issues with the AVD settingscreen not loading:
