[APP][Pro] Advanced Virtual Device (Device Capabilities App) with Unique Text Status Indicator
I have a HPE2023 running on v12.8.2 and Device Capabilities APP v2.16.2. I often face an issue regarding my virtual devices. If I add or modify a field in it, then delete and/or add modify again, after the refresh of the device by clicking SAVE, a “fake” icon field remains in the virtual device.
If I try to find this “fake field” inside the flow cards of the device it doesn’t exist, but in the device it is.
I have tried to save and close the device several times, in some case the “fake field” disappears in other case not.
Did anyone face same issue?
Any help will be appreciated
Can you add a few screenshots, I don’t understand what you mean by “fake”.
Hi Peter,
For sure
Above an example. If you see the field which is signed as “Yes/No” it is a boolean field which I can’t remove anymore from my virtual device. In the field list I am not capable to find it. I have already restarted Device Capabilities APP and Homey too but the “fake” field is still present
Ah, it’s a “ghost” capability as I would call it.
In my experience, after editing an AVD capabilities, the screen you showed gets refreshed when you open a devices’ settings from an other device in an other zone.
In theory an app- or Homey restart should have the same result, I can’t tell why the deleted capability keeps appearing in your case.
Thanks Peter,
So you have no other idea apart the Device Capabilities APP or Homey restart? Unfortunately both actions didn’t solve my problem :pensive_face:
If there are no other suggestions I will go to open a case for this issue on Device Cap. APP
Is it not located under Button?
(A button not clickable or anything can showup under Sensor)
Please send me a PB with a complete screenshot of the avd settings?
Hi Arie, I have just submitted an issue in Bitbucket.
Below the full snapshots:
I have just attached the TEF in the issue opened in Bitbucket. If you need other info let me know. I have another AVD with a similar issue.
Arie meant a screensot of these settings, @Domenico_Etere
(And please add them to the bitbucket issue)
Hi Peter,
Yes, already added to the bitbucket issue
Am I missing something? None of my devices show up under the “condition”. Is there something that needs to be turned on so I can check if for example is turned on or off? See attached image for the options I have.
You can check the value of the virtual device’s capabilities via Logic cards (capability tag is equal / greater than / smaller than).
Eine Lösung gefunden ??
Do both fields show up under sensor?
@Torsten_Zauner, Please write in English, as this is an English-language topic.
No, no solution found. Currently, it doesn’t seem possible to create an AVD for home batteries.
What do you mean exactly, @Arie_J_Godschalk?
These are the settings we used:
However, the AVD isn’t displayed at all in the Energy Dashboard.
But in the AVD, on the Sensor page, are import and export both shown?
Because right now, you have 2 fields Energy both checked for Create Real Fields, which is not possible (it would create 2 fields internally called “meter_power").
I need to check how i can implemented 2 “real" fields for meter_power.
Yep…
etin = energy total in (import)
etout = energy total out (export)
I understand what you mean and, of course, it’s logically.
But I guess this isn’t the problem.
I created myself an AVD for our Smart Meter. It also provides values for energy imports and exports and I check marked both meter_power fields with “Create Real Fields”. Both values, i.e., energy imports and exports, are displayed correct in the Homey Energy Dashboard.
The only difference to the Home Battery AVD is, that the device class of the Homey Battery AVD is set to Battery and the device class of the Smart Meter is set to Sensor.
Therefore, my assumption is that the problem may lie in the device class Battery.
When I create a new AVD the first field defined as Power appears as Energy (Energieverbruik) in Insight instead as it field name.
