Mine seems to be working - 24 minutes since last data…
Mine is also working, just checked it. Maybe remove the device and add it again if nothing else works. Did you try restart the app?
You filled in only appkey/appsecet and no user/pw right?
Maybe login to hq developer portal and recreate the ‘app’ in there. (=new appkey/appsecret). In that case follow the steps from post 1 carefully.
@BufferOverflow - Thank you for the tip! Creating the new app in hq developer portal solved the issue.
I added “Mode is” in version 1.4.3 available for testing. Let me know if it work as expected ![]()
https://homey.app/en-se/app/com.husqvarna.automower/Husqvarna-Automower-Connect/test/
Great! -Thnx! - I will test it! ![]()
Any interest in a dashboard widget?
I have been playing with something similar to the Husqvarna mobile apps “map” view - drawing out the positions on a satellite image.
Maybe it could also include next start and error code.
Ideas or opinions?
Hi! This change is awesome! Do you know approximately when v1.4.3 will be pushed to production? I see that it was pushed to testing earlier
Is it the “Mode is” feature you are thinking of?
I can release 1.4.3 anytime as it is a very small change and the ~10 testers have at least not said anything.
There is also a bigger change based on an external PR adding “EPOS zone” support in the pipeline
But this will take some additional time.
But 1.4.3 we could do release this weekend.
Yes, the ”Mode_is” will be very helpful. That’s amazing, looking forward to this weekend then ![]()
I apologize for not getting back to confirm that “Mode is” is working perfectly! Thanks again!
Great work, it works perfectly.
Suggestion for a dashboard feature, maybe in a upcoming release; Would it be possible to have a Dashboard that is something like the app for Homey Pro, called "[ Spacey Plan ] by Ludwig Aldrin ? It´s actually quite well made, in that it allows the user to add a floorplan for your house as a picture file, and then you can add whatever you as the user might have in the specific rooms/floors of your house. Could that ba a option for our automovers? since every garden is by design unique, could it be something to have for this Husqvarna app you´ve made?
Anyway, just a thought.
Great app, thanks a lot for your work ![]()
Thanks for the feedback and really nice to hear that it works for you! ![]()
Cool idea with a “space plan”. Are you thinking it can be used for geo-location stuff or did you have something else in mind?
Thank you for a very functional app! However, a few (new) status messages are missing for my Automower R6V related to the frost guard feature and possibly other features. It currently just says “NOT_APPLICABLE” when frost guard kicks in.
Such a brilliant app - thanks a lot Magnus Ohlsson! One addition that’d be amazing is workzones (available in all the new Husqvarna models). Some thoughts on how this could be useful:
- Skip areas when you’re not at home If the mower has a tendency to get stuck in certain areas, disable them when you’re not around to rescue it, in case it gets stuck. Much less hassle!
- Weather-aware area selection. After heavy rain, skip the shaded back area that stays soggy and only mow the sunny front lawn. Right now it’s all-or-nothing.
- Presence-based zoning. Mow the play area / trampoline zone / parking area only when nobody’s home
- One-click mowing Use it to make a card in Homey that sends the mower straight to the driveway etc (great for parents/grandparents who just need a simple way to operate the mower)
- Keep mower out of sprinkler areas If sprinklers are active, avoid mowing these areas
Every one of these is currently impossible in Homey and impossible in the Automower Connect app too, since it has no conditional logic. This is exactly the kind of thing a hub is for.
How it could work
The Automower Connect API already supports this. I’ve confirmed the following from the ioBroker and Home Assistant integrations (I couldn’t verify the exact request payload against Husqvarna’s official API reference, since it sits behind a developer-portal login — worth double-checking before implementing):
- The mower status response includes a
workAreasarray withworkAreaId,name,cuttingHeightandcalendarper area. - There’s a
capabilities.workAreasboolean that indicates whether the mower supports the feature at all. - There’s a
startInWorkAreaaction taking aworkAreaIdand an optionaldurationin minutes (0 = override until further notice). It goes to the same actions endpoint the app already uses for Start, Park and ResumeSchedule.
So the implementation could be fairly contained:
- New “Then” card: “Start in work area [dropdown] for [number] minutes.” The dropdown gets populated from the
workAreasarray already present in the status response — no extra API calls, so no impact on the 10,000/month rate limit. - Optional: a flow token or condition for the current/last work area, so flows can react to which area the mower is in.
- Optional: a “Set cutting height for work area” action, since
cuttingHeightis exposed per area. Home Assistant does this as one number entity per area. - Graceful degradation: only register the cards when
capabilities.workAreasis true, so nothing changes for users on older wire-boundary models.
I’ll be happy to test on my own setup if that helps. Thanks in advance for considering it!
