[APP][Pro] MOVA Robovacuum
Hi everyone,
I’ve published a community app to control MOVA robot vacuums from Homey Pro, using the MOVAhome account you already have.
You can start, pause, stop and dock, choose vacuum / mop / vacuum+mop, set suction, water and CleanGenius, follow battery and status, reset consumables, and put a live floor map on your dashboard. Flows are included.
Pairing is email + password only. If you signed up with Apple ID, set a password in the official MOVAhome app first (Forgot password / Set password). A login code from mova.tech will not work.
Tested with a MOVA V70 Ultra Complete as MOVA Model.
MOVA M1 also confirmed as working, use “Dreame model” as device to add this. These are older robots working in the background on the Dreame platform and not on the MOVA platform.
Other MOVA vacuum models on MOVAhome should work too — if yours does (or doesn’t), please say so here.
This is a community app and is not affiliated with MOVA or Dreame.
Questions, bugs and device reports are welcome in this topic.
Enjoy the automated cleaning!
Oh wow, this is wonderful! I installed it immediately.
Is it possible to tell it to clean a specific room?
Hi @Johanneso,
I’ve added a new function for this. In the app settings: fetch the rooms first. Then in the THEN flows you can select to either mop, vacuum or both the selected rooms by adding them as logic tags to the text field.
It’s currently in test here: MOVA Vacuum | Homey
Let me know if it works for you and what you think about it!
Hello. Developer, could you please add a Korean server to the app? I think there should be a separate Korean server so that I need to select it to see the products, but the Korean server isn’t displaying, so I can’t add products.
