[APP][PRO] Ecovacs GOAT Mower app
H
Hi again everyone!
Heads-up: Its no point to submit a app log in Homey before i know who you are. So if you do, please add a reply here in the forum or a direct message so i can help you.
Quick update on the Ecovacs Goat app built with the new Python SDK v3.
Final version is done (v 1.3.0) and it has been tested thorough to get the Homey app into a good factuality and quality app that it deserves.
I have spend many many hours on this project and hope its appreciated by all Ecovacs homeowners.
I now see that the project is complete and that all functions should now be in place from what I can find out from mower and the api.
The app will of course be maintained, but I feel that this one is now so finished that it can safely stop getting major improvements.
Have a good summer and good luck with the lawn mowing
What is core cloud:
  • Cloud authentication & Device pairing.
  • Basic commands
  • Basic status polling.
  • MQTT JSON API (Build up from scratch)
Update 1.7.6 — Insights improvements
What’s now in Insights:
  • Mowing on/off — A new onoff toggle capability has been added. It turns true when the mower starts mowing and false when it stops. This shows up cleanly in Homey Insights as a boolean timeline labelled “Mowing” / “Not mowing”.
  • alarm_rain — Now logged in Insights as a boolean timeline.
  • mower_connected — Now logged in Insights as a boolean timeline.
  • Numeric capabilities — measure_mow_time, measure_mowed_area, measure_total_area, measure_temperature, measure_blade_life, and measure_rssi are all now enabled for Insights charting.
Old update log:
Added on 1.7.1
  • Enhanced activity log with zone/area/time detail, added zone tag to Status widget, two new Flow action cards (cut angle + auto direction), dynamic mowing progress bar, and full French (fr) language support.
Added on 1.6.2
  • Fixed rain protection alarm staying active for double the configured delay after rain stops; fixed “Mower is back in base” flow card not firing reliably; fixed global notifications for mowing finished and rain defaulting to off for existing devices; fixed repair flow stuck on loading screen indefinitely
Added on 1.6.0
  • Improved app settings page and general fixes. Resolved numerous bugs across various functions. Adjusted notifications.
Added on 1.5.2
  • Rain alarm fix, notifications now translated & app-level only, cutting height slider removed, Flow card warning fixed, and Repair device now works
Added on Version 1.1.2 - 1.1.5
  • Full multi-language support (NO, SV, DA, DE, NL) across all capabilities, Flow cards, and App Store listings, plus Homey Community topic link added
  • Advanced Flow cards (Triggers, Conditions).
  • Zone cleaning / Specific area mowing.
  • Edge cut functionality.
  • Detailed battery and error state parsing.
  • Cutting height adjustments.
  • Cut direction flowcard for supported GOAT mowers
Added on Version 1.1.10
  • Total mower areal
  • Added SafeProtect (only on supporter mowers) - (found in device settings)
  • Added TrueDetect (only on supporter mowers) - (found in device settings)
  • Added MoveUp Warning (only on supporter mowers) - (found in device settings)
  • Flow actions: Zone is now setable
  • Added Triggers on SafeProtect, TrueDetect and MoveUp
  • Added Volum sound control flow
  • Added Child lock flows
  • Added Find the mower (w/ sound)
  • Turn border cut at session on/off
Added on Version 1.2.1
  • Redesign off control capabilities
  • Removed onoff toggle
  • Flowcard deep function test
  • Added alarms to triggers and capabilities
Added on Version 1.2.10
  • Zone settings in mower device implementet (tested thorough)
  • AI settings in mower device implementet (tested thorough)
  • Cleaned up flowcards
  • Adjust cut height from 60mm to 80mm
  • Fixed GetVolume/VolumeEvent read-back
  • Add GetCutDirection/CutDirectionEvent read-back
  • Moved ResetLifeSpan
  • Bumped the MQTT JSON commands to see more functions to the API
  • 1.3.6 - Fixed start/stop/pause commands and state updates for the GOAT G1 family, which uses a different command set than newer GOAT models
  • 1.3.5 - Fixed start/stop and settings commands failing for non-EU accounts (wrong cloud datacenter), and stopped repeated timeouts on models that don’t support certain status requests
Added on Version 1.4.0
  • The app-settings page is now containing more information about your mowers, you also got a timeline/activity monitor.
  • Dashboard/Widgets ready from v 1.4.2
  • 1.4.4 - Added support for new GOAT A3000 RTK LiDAR models and live map widget (Testing)
  • Version 1.4.6 — Live map of mower is tested and ready. in older models the maps contains less detailed
Added on Version 1.5.2
  • Added custom view of capabilities on device. Added brush lifespan and weed cutter lifespan to supported mowers. Fixed bugs
Added on 1.5.11
Ecovacs has changed their authentication to require signature, certificate pinning.
The fix:
Update your app (v1.5.11)
Open app settings
Verified email: (guide under)
Restart the app (only if its not reconnects)
Go to App Settings → Device Verification → click “Send Code to Email” → enter the 6-digit code → click “Verify Device”. This is a one-time action per Homey.
Remember to save credentials so your verified code and login is stored correctly
Expanded all GOAT hardware profiles to match the diffrent functions. Some users may not have all functions. This depends on your model
Submit bugs or missing models: If you mower models are missing, please write your model below for additional support for your mower.
Here’s the full language support picture for the app:
Language Code UI strings (locales/) Store description (README.*.txt)
English en :white_check_mark: :white_check_mark: (README.txt, default/fallback)
Danish da :white_check_mark: :white_check_mark:
German de :white_check_mark: :white_check_mark:
Dutch nl :white_check_mark: :white_check_mark:
Norwegian no :white_check_mark: :white_check_mark:
Swedish sv :white_check_mark: :white_check_mark:
French fr :white_check_mark: :white_check_mark:
7 languages total
# Capability ID Data Type Description
1 mower_state enum Mower status (idle, mowing, returning, error, etc.)
2 cmd_start boolean Button: Start mowing
3 cmd_stop boolean Button: Stop and finish
4 cmd_pause boolean Button: Pause
5 cmd_resume boolean Button: Resume mowing
6 cmd_edge_cut boolean Button: Edge cutting
7 cmd_dock boolean Button: Return to base
8 goat_cutting_height number Slider: Cutting height (1–10)
9 mower_connected boolean Sensor: Connected to Ecovacs Cloud
10 measure_battery number Sensor: Battery percentage
11 alarm_battery alarm Alarm: Low battery
12 measure_rssi number Sensor: Wi-Fi signal strength (dBm)
13 measure_mowed_area number Sensor: Mowed area this session (m²)
14 measure_mow_time number Sensor: Mowing time this session (min)
15 alarm_rain alarm Sensor: Rain protection active
16 measure_blade_life number Sensor: Remaining blade life (%)
17 measure_total_area number Sensor: Total mowed area
18 cmd_find_mower boolean Button: Find mower (sound)
19 cmd_reset_blade_life boolean Button: Reset blade life
20 safe_protect boolean Sensor: SafeProtect status
21 true_detect boolean Sensor: TrueDetect status
22 moveup_warning boolean Sensor: Lifting warning
23 child_lock boolean Sensor: Child lock status
24 measure_temperature number Sensor: Battery temperature (°C)
Supported Models:
HOWTO Setup
Prerequisites
Before pairing the mower you need to enter your Ecovacs account credentials in the app settings:
  1. Open Homey → Apps → ECOVACS GOAT → Settings
  2. Enter your Ecovacs username and password
  3. Tap Test Connection to verify
  4. Go to App Settings → Device Verification → click “Send Code to Email” → enter the 6-digit code → click “Verify Device”. This is a one-time action per Homey.
Pairing
  1. Go to Devices → Add Device → ECOVACS GOAT
  2. Your mower(s) will appear automatically — select yours
  3. Tap Add — the device is ready
Advanced Settings
Found under Device → Settings:
Setting Default Description
SafeProtect On Automatically stop when an obstacle or unsafe condition is detected
TrueDetect 3D On Use LiDAR to identify and avoid obstacles more accurately (LiDAR models)
MoveUp Warning On Trigger an alarm when the mower is lifted off the ground
Rain Delay On Trigger an alarm when its detected rain, time delay set
Animal Protect On Set your mowers to operate between spesific time
AI Detection On Set up for recognition of objects
Changes here are sent to the mower immediately.
Repair / Reconnect
If the device shows as unavailable:
  1. Long-press the device card → Repair
  2. The app will reconnect to the Ecovacs cloud automatically
  3. On success it confirms — no re-pairing needed
I can log in but my version is not supported yet i guess? A1600 RTK.
Did you try to pair?
After update it connects. Will test tomorrow. What I would hope to get is to set cut direction. Thanks so far!!
Cut direction is on my agenda, but still looking for the exact commands. Cutting height is implemented.
I have now managed to find this in the commands for cutting directions/angel and will implement this in an update. I am initially thinking of only having this in a flowcard option. This is in update to v1.1.5
Better and better!! Very nice job!
Will zone/area selection for cutting be possible?
Yes it will be, i currently doing some tests on my mower first. Rolling out public soon, test it if you like. You find the 1.1.10 test in Homeys app listing under changelog
In the latest version 1.2.1 its been fixed all bugs related to the flowcards and capabilities that didnt send all the right commands.
I have tested all on my GOAT O-1200 RTX LIDAR PRO and all functions are now ok.
I have remove the toogle onoff because that did a conflict on the stat commands in the mower.
I added a update driver with new capabilities, if you experience somehow missing capabilities i suggest you do a reinstall this time.
This looks to be the final and stable version (1.2.1) waiting for approval by athom
Hope you will enjoy the Homey App :slightly_smiling_face:
Update 1.2.8: Now rain delay/animal protection/AI features in device settings are working, fixed volume & child lock payloads, fixed warnings not working in the device capabilities.
Final notes ! :slight_smile: V 1.3.0 is found in changelog, and will be public by Athom soon.
You have not been able to set the cut direction by a flow yet? I also see that the cut direction says 0 degrees in advanced settings, but it is 195 really. So does it read the cut direction from the robot?
i did have it, but the problem is that the offical Ecovacs, controls this in the zone/area settings. Like i have now implemented in the device settings. This is the beste option to get bouth Homey and Ecovacs to speak together. I really didnt find a good solution to do a global override on zone adjustments.
And in the device settings you can sync your zone settings from mower. You just type in zone number and press save, and it syncs.
I will see more into the global cutting angel. I now have figured out rain alarm in the goat mower. But this and other warnings will come in an update.
But instead of pumping out versions ill collect them together in one realise.
I need to do alot of reverse engineering to see witch message commands its sending from mower to API because the official API is locked from public.
In my Ecovacs settings I have only one cut direction. Through an Home assistant integration I can read this as 195 degrees. I see 0 in this and try to change it but it reverts to 0.
Hei, jeg har lastet inn appen. GOAT O600 RTK er lagt inn i Ecovacs app, men den dukker ikke opp i homey, selv etter signin. Vet du hva problemet kan være?
Did you successfully login to the cloud in settings?
I see the device settings the rain and animal setting is not sync from the mower when its opening. This will be fixed in next update
Yes. Got the message - saves, connected but no device found on this account
I have added a test version to try out
