Introducing Teslemetry - Real time data from Tesla vehicles
Teslemetry was built to provide the best Tesla integration possible for Home Assistant, and now its coming to Homey. Starting at USD$2.50 per month, a Teslemetry subscription provides easy access to Tesla Solar/Powerwall data, and for an additional USD$2.50 per month per vehicle Teslemetry provides unlimited real-time vehicle data. Vehicle commands are provided near cost ($2.50 for 2000 commands).
Unlike the free Tesla Fleet app, Teslemetry doesn’t require a developer account so is much easier to setup, and doesn’t poll your vehicle for data (which can get costly).
Unlike Tessie, you can configure the frequency that data is streamed from your vehicle with Teslemetry, allowing you to choose whats important to you, while also being significantly cheaper.
The app is currently about 80% feature complete, but if your interested in giving it a test and providing feedback, new customers can use the discount code L6CEZBLMN3 to get their first month free.
To get started, sign up at https://teslemetry.com and install the Teslemetry test app:
Thanks for building this guys!
I’m getting a redirect loop with auth.tesla.com so kind of stuck at the moment and can’t add the gateway or vehicle, but excited for this to work.
What device are you using to do the pairing? (Android/iOS/Windows/Mac)
A potential work around is to login to teslemetry.com/console in your default browser first, then retry adding the device in Homey.
I’ll need to try reproduce the login loop, as I haven’t had that issue during development.
I was having the issue on IOS 26.1. After your post I also tried MacOS Sequoia 15.6 which has the same problem.
Just had success adding the gateway via Windows 11. Will do the charger and EV via the same method.
I believe this is a Safari specific issue with that specific page. I am pushing a workaround to the website now, but an alternative workaround is to use a browser other than Safari.
EDIT: The pairing on Safari is now fixed.
