# Zwave of my Homey Pro Early 2023 stopped working
**URL:** <https://community.homey.app/t/zwave-of-my-homey-pro-early-2023-stopped-working/78298>\
**Tags:** homey-pro\
**Created:** [March 23, 2023, 11:51pm UTC](https://community.homey.app/t/zwave-of-my-homey-pro-early-2023-stopped-working/78298 "2023-03-23T23:51:46Z")\
**Showing post:** 5
**Post date:** [March 24, 2023, 8:11am UTC](https://community.homey.app/t/zwave-of-my-homey-pro-early-2023-stopped-working/78298/5 "2023-03-24T08:11:02Z")
> [@Cuprani](#):
> Not only because that would take a lot of time
This is life-saver in such situations, using very often thanks to test/migrations/re-migrations…
> [@Martijn\_C](#):
> be a serious issue if nodes are randomly removed
So let us know, what you will learn. Basically you will see nodes and the status here - [Homey Developer Tools](https://tools.developer.homey.app/tools/zwave) - in case you see it as Route = Unknown, the device it’s either powered down or left the mesh.
_[View the full topic](https://community.homey.app/t/zwave-of-my-homey-pro-early-2023-stopped-working/78298)._
