# Zone inactive for x minutes doesn't work with variable... How to troubleshoot
**URL:** <https://community.homey.app/t/zone-inactive-for-x-minutes-doesnt-work-with-variable-how-to-troubleshoot/109598>\
**Tags:** flow, homey-pro\
**Created:** [May 9, 2024, 2:19pm UTC](https://community.homey.app/t/zone-inactive-for-x-minutes-doesnt-work-with-variable-how-to-troubleshoot/109598 "2024-05-09T14:19:50Z")\
**Showing post:** 8
**Post date:** [May 9, 2024, 7:26pm UTC](https://community.homey.app/t/zone-inactive-for-x-minutes-doesnt-work-with-variable-how-to-troubleshoot/109598/8 "2024-05-09T19:26:33Z")
Especially with new flows, or complex flows, it’s much easier to troubleshoot.
F.e. actioncards are ‘fire and forget’; even when zigbee and zwave devices normally report their status back, the flow does not check that acknowledgement, and just says “I turned on device X”.
Now, the log action card gets triggered along with the device action card \> you now know the flow works, but there’s some issue with turning on device X.
There’s even a script available to add SL cards to all flows
> [@\[APP\]\[Pro\] Simple (Sys) LOG - Use this app for Simple (Sys) Logging](https://community.homey.app/t/app-pro-simple-sys-log-use-this-app-for-simple-sys-logging/77533/6):
> Script to automaticly include Simple Logging cards into your flows Use this script to automaticly add logging cards to your (advanced and normal) flows: It adds logging to each flowcard’s error catch in advanced flows. Also it adds cards to the triggers (WHEN), conditions (AND) and actions (THEN). It will generate one Automater flowcard in each flow. This card can be used to configure each flow on it’s own: Update: When you set this to No, the Autmoater card itself will not be changed when …
_[View the full topic](https://community.homey.app/t/zone-inactive-for-x-minutes-doesnt-work-with-variable-how-to-troubleshoot/109598)._
