# Zigbee odd route - leeds to unresponsive devices
**URL:** <https://community.homey.app/t/zigbee-odd-route-leeds-to-unresponsive-devices/49997>\
**Category:** Questions & Help\
**Tags:** zigbee\
**Created:** [August 2, 2021, 8:05am UTC](https://community.homey.app/t/zigbee-odd-route-leeds-to-unresponsive-devices/49997 "2021-08-02T08:05:01Z")\
**Posts on this page:** 7\
**Page:** 2
<div class="post-metadata">
**Author:** ![robertklep](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/robertklep/32/160628_2.png) [@robertklep](https://community.homey.app/u/robertklep)\
**Post date:** [August 9, 2021, 9:06am UTC](https://community.homey.app/t/zigbee-odd-route-leeds-to-unresponsive-devices/49997/21 "2021-08-09T09:06:52Z")
</div>
Sounds like you may have too many Zigbee devices connected to Homey.
**Author:** ![Hans-Jochen\_Nissen](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/hans-jochen_nissen/32/9752_2.png) [@Hans-Jochen\_Nissen](https://community.homey.app/u/Hans-Jochen_Nissen)\
**Post date:** [August 9, 2021, 10:07am UTC](https://community.homey.app/t/zigbee-odd-route-leeds-to-unresponsive-devices/49997/22 "2021-08-09T10:07:58Z")
</div>
11 router device and 5 end device
**Post date:** [August 9, 2021, 10:21am UTC](https://community.homey.app/t/zigbee-odd-route-leeds-to-unresponsive-devices/49997/23 "2021-08-09T10:21:11Z")
</div>
That shouldn’t be a problem. Have you ever performed a Zigbee reset?
**Post date:** [August 9, 2021, 10:34am UTC](https://community.homey.app/t/zigbee-odd-route-leeds-to-unresponsive-devices/49997/24 "2021-08-09T10:34:54Z")
</div>
Yes, twice. After the first 5.x rc and after the update to 5.0.4 when problems started.
Do you think I should try it again?
**Post date:** [August 9, 2021, 10:38am UTC](https://community.homey.app/t/zigbee-odd-route-leeds-to-unresponsive-devices/49997/25 "2021-08-09T10:38:34Z")
</div>
I just now read that you’re using Osram devices. Those don’t always work well together with others, especially Aqara devices.
Also, if I understand correctly, your main issue seems to be that when turning on/off multiple devices at once, some devices don’t react. Is that correct? Because that’s been an issue with Homey for quite some time now and isn’t limited to Zigbee.
**Post date:** [August 9, 2021, 12:03pm UTC](https://community.homey.app/t/zigbee-odd-route-leeds-to-unresponsive-devices/49997/26 "2021-08-09T12:03:29Z")
</div>
No, there are not several devices that switch on / off at the same time. There are different times and different scenarios on the different devices. So you think I should replace the osram units? Is it only with Homey that osram has problems?
I have a hue lamp. It seems like nothing meshes through it?
**Post date:** [August 9, 2021, 12:08pm UTC](https://community.homey.app/t/zigbee-odd-route-leeds-to-unresponsive-devices/49997/27 "2021-08-09T12:08:12Z")
</div>
You can _try_ and see if it works better without the Osram devices, but it’s not a guaranteed fix for your problems. Also, Zigbee devices make up their own mind on how they are routed, you (or Homey) cannot control it.
[Previous page](https://community.homey.app/t/zigbee-odd-route-leeds-to-unresponsive-devices/49997.md?page=1)
