# Zigbee issue with Homey Pro 2026 migrated from Homey Pro (Early 2023) using USB Restore
**URL:** <https://community.homey.app/t/zigbee-issue-with-homey-pro-2026-migrated-from-homey-pro-early-2023-using-usb-restore/147238>\
**Tags:** bugreport\
**Created:** [December 18, 2025, 1:02pm UTC](https://community.homey.app/t/zigbee-issue-with-homey-pro-2026-migrated-from-homey-pro-early-2023-using-usb-restore/147238 "2025-12-18T13:02:30Z")\
**Showing post:** 127
**Author:** ![SunBeech](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/sunbeech/32/111391_2.png) [@SunBeech](https://community.homey.app/u/SunBeech)\
**Post date:** [January 18, 2026, 9:00pm UTC](https://community.homey.app/t/zigbee-issue-with-homey-pro-2026-migrated-from-homey-pro-early-2023-using-usb-restore/147238/127 "2026-01-18T21:00:53Z")
See the post of @Jonathan_Draper:
> [@Zigbee issue with Homey Pro 2026 migrated from Homey Pro (Early 2023) using USB Restore](https://community.homey.app/t/zigbee-issue-with-homey-pro-2026-migrated-from-homey-pro-early-2023-using-usb-restore/147238/102):
> OK, experiment in progress. So far have restored new (modded HP2023) Homey from a recent cloud backup and verified that Zigbee still behaving as it was before. Specifically in my case: Some Zigbee devices actually worked fine after the restore, even without repairing Some Zigbee devices didn’t show up as needing repair (no red triangle) but could not be controlled by Homey. For these devices, multiple attempts to repair them failed and after trying, those devices then showed with a red triang…
As the Zigbee devices are not removed from Homey after the Zigbee reset (just unavailable), you don’t have to repair your flows. You do have to repair all your Zigbee devices. Note: repair, not re-pair (so via the Maintenance \> Try to repair option).
I haven’t tried this myself, but you can find multiple (recent) reports on this forum on this behavior, like the one linked above. Some other posts:
- [Zigbee - Aqara Window/Door Sensor Connection Problem - #17 by robertklep](https://community.homey.app/t/zigbee-aqara-window-door-sensor-connection-problem/148528/17)
- [Connectie problemen veel devices op homey pro 2026 - #7 by Hendrik-Jan\_Post](https://community.homey.app/t/connectie-problemen-veel-devices-op-homey-pro-2026/149450/7)
I don’t think anyone can provide you with assurances that you specific device will work. You’ll just have to try it yourself. But if your device worked on your HP23, then it should also work on the HP26.
_[View the full topic](https://community.homey.app/t/zigbee-issue-with-homey-pro-2026-migrated-from-homey-pro-early-2023-using-usb-restore/147238)._
