# Zigbee issue with Homey Pro 2026 migrated from Homey Pro (Early 2023) using USB Restore
**URL:** <https://community.homey.app/t/zigbee-issue-with-homey-pro-2026-migrated-from-homey-pro-early-2023-using-usb-restore/147238>\
**Tags:** bugreport\
**Created:** [December 18, 2025, 1:02pm UTC](https://community.homey.app/t/zigbee-issue-with-homey-pro-2026-migrated-from-homey-pro-early-2023-using-usb-restore/147238 "2025-12-18T13:02:30Z")\
**Showing post:** 10
**Author:** ![SunBeech](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/sunbeech/32/111391_2.png) [@SunBeech](https://community.homey.app/u/SunBeech)\
**Post date:** [December 20, 2025, 4:00pm UTC](https://community.homey.app/t/zigbee-issue-with-homey-pro-2026-migrated-from-homey-pro-early-2023-using-usb-restore/147238/10 "2025-12-20T16:00:11Z")
I am actually running into similar problems after migrating from my Homey Pro 2023 to a Homey Pro 2026 SE:
- Zigbee devices are unresponsive after the migration;
- Zigbee devices cannot be repaired (via Maintenance): the device is found but the pairing process ends up in an error saying Homey cannot connect to the device. Also the device remains in pairing mode;
- New Zigbee devices cannot be added: same issue as mentioned in the previous point.
Ik have tried:
- Migrating based on both a local backup as well as a cloud backup;
- Switching power adapters (using the HP23’s slightly higher voltage adapter on the HP26);
- Re-installing apps;
- Re-installing the Homey firmware via the USB tool.
All to no avail.
The last thing I can think of is to reset the Zigbee network on the HP26. But that will remove all Zigbee devices, which need to be paired/set up from scratch. I have about 70 Zigbee devices.
I have reached out to Athom. Hopefully they can help out.
In the mean time I switched back to my HP23.
_[View the full topic](https://community.homey.app/t/zigbee-issue-with-homey-pro-2026-migrated-from-homey-pro-early-2023-using-usb-restore/147238)._
