# Webhook via local network
**URL:** <https://community.homey.app/t/webhook-via-local-network/17252>\
**Created:** [August 23, 2019, 4:08pm UTC](https://community.homey.app/t/webhook-via-local-network/17252 "2019-08-23T16:08:03Z")\
**Showing post:** 33
**Post date:** [December 21, 2025, 4:55pm UTC](https://community.homey.app/t/webhook-via-local-network/17252/33 "2025-12-21T16:55:47Z")
Why search for an other port?
Did you test with the used Homey SHS port first?
If you didn’t pick your own, it should be:
 ![Screenshot_20251221_175436_Firefox](https://us1.discourse-cdn.com/flex025/uploads/athom/original/3X/0/4/04f0ed4c60e92938753ba7b5814d96f46359470c.jpeg)
Works perfecly fine with my linux/Docker setup
`http://192.168.12.90:4859/webhook?event=2026&tag=pro`
[http://ip-adresse:7777/webhook?event=Test&tag=my\_tag](http://ip-adresse:7777/webhook?event=Test&tag=my_tag)
About “Test”:
I always refrain from using capitals, because it’s not a Windows system, which doesn’t care;
linux however is _ **case sensitive** _
An accidental error is right around the corner:
- This flow won’t trigger, `test` does not match:
- This flow will trigger, `Test` is a match:
> [@witnic](#):
> When I try it using the “Test” button in the flow, it works.
That’ll always work, because the test command replaces the trigger card.
In other words, you can’t test the functioning of a flow trigger with the test button.
_[View the full topic](https://community.homey.app/t/webhook-via-local-network/17252)._
