# Wait until
**URL:** <https://community.homey.app/t/wait-until/88675>\
**Tags:** flow, advancedflow\
**Created:** [September 3, 2023, 11:03am UTC](https://community.homey.app/t/wait-until/88675 "2023-09-03T11:03:17Z")\
**Showing post:** 5
**Post date:** [September 3, 2023, 11:01pm UTC](https://community.homey.app/t/wait-until/88675/5 "2023-09-03T23:01:22Z")
> [@Julen\_Arambarri\_Elor](#):
> How can I make it send me a notification (just once) only when the power drops below 8 watts?
You can add the action card “Disable flow [Flow\_Name]”, to disable the flow after a notification was sent.
Also add the action card “Enable flow [Flow\_Name]” with 2 hour delay (the time of a dry cycle)
An other way is to create a Y/N variable X
When..
-dryer power changed
And..
-dryer power is below 8
-logic Variable X is NO
Then..
-send notification
-set logic variable X to YES
-set logic variable X to NO with 2 hour delay
> Also, is there a way to make the notifications interactive? Like, can I perform an action directly from the notification itself?
You can use [Telegram Notifications app](https://homey.app/a/com.spkes.telegramNotifications), to send a pre-defined question to a Telegram user (or group) when a dryer notification was received;
You can use pre-defined answers to choose from, or let the user enter a valid value or word(s), which can trigger (parts of) a flow:
> [@The Flow Exchange(r) - Exchange Your Flows with Others!](https://community.homey.app/t/the-flow-exchange-r-exchange-your-flows-with-others/68981/49):
> Start flow actions using a user entered value, by a reply to a predefined question on Telegram The Telegram app by @spkesDE has the functions to start a flow(part) by replying to a question with picking from predefined answers, but, also, by entering a value. That value can be used to set a target temperature f.i. Built-in conditions: flow should not respond to any message with coincidental valid values the entered value should be within a defined value range the user should be informed …
The flow is importable
_[View the full topic](https://community.homey.app/t/wait-until/88675)._
