# Violet + BADU Blue — Pool control for Homey
**URL:** <https://community.homey.app/t/violet-badu-blue-pool-control-for-homey/157109>\
**Category:** Apps\
**Tags:** homey-pro\
**Created:** [July 10, 2026, 10:16pm UTC](https://community.homey.app/t/violet-badu-blue-pool-control-for-homey/157109 "2026-07-10T22:16:41Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![Torsten\_Sturm](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/torsten_sturm/32/77900_2.png) [@Torsten\_Sturm](https://community.homey.app/u/Torsten_Sturm)\
**Post date:** [July 10, 2026, 10:16pm UTC](https://community.homey.app/t/violet-badu-blue-pool-control-for-homey/157109/1 "2026-07-10T22:16:41Z")
</div>
Control and monitor your **PoolDigital Violet** or **BADU Blue** pool controller straight
from Homey — live water chemistry, pump and equipment state, dosing, Flow automations, and
an optional water‑balance safety net that warns you _before_ your water turns corrosive. All
local, no cloud account.
> ⚠ **This is a Test (beta) release.** It’s on the Homey App Store’s _test_ channel and
> runs well on my own pool, but it hasn’t been through full store certification yet — expect
> the odd rough edge, and please report anything that looks off. That’s exactly why I’m
> posting here.
👉 **Install (Homey App Store):**
> **[Violet Pool Control | Homey](https://homey.app/en-us/app/de.neunbft.violet/Violet-Pool-Control/)**
> Protects your pool's water balance — before problems start.
### What is this?
A local Homey Pro app for the **Violet** pool controller by PoolDigital (sold as **BADU
Blue** by Speck Pumpen — same hardware). It talks to the controller’s on‑device API over
your LAN, so there’s no PoolDigital cloud login involved. Readings feed **Insights** and
**Flow** ; an opt‑in control mode lets Homey command the equipment.
### 📊 What it shows
The device adapts to your installation — tiles appear only for hardware the controller
actually reports:
- 🌡 Water temperature, **pH** , **Redox/ORP** , free **chlorine** (if a probe is present)
- 💧 Filter **pump** (state, speed stage, runtime today)
- 🔥 **Heater** , ☀ **solar** , 🍃 **eco** mode (with runtimes)
- 🪟 **Cover** (open/closed/moving), 💡 **light**
- 🚰 **Water refill** , **overflow tank** state, **water level**
- 🧪 **Dosing** per channel — dosing now, dosed today (mL), estimated days of chemical left
- 🔁 **Backwash** running
- 🩺 Optional diagnostics — firmware, uptime, CPU temp, memory, last error
Plus tile **alarms** : water balance, dosing blocked, chemical low, backwash‑valve fault,
overflow dry‑run and overfill.
### 🧪 The LSI water‑balance safety net (the reason this app exists)
Most pool integrations show you pH and temperature. This one can also compute the
**Langelier Saturation Index (LSI)** — the industry measure of whether your water is
**corrosive** , **scaling** , or **balanced** — and warn you when it drifts.
Why care? **Corrosive water attacks copper, heaters and heat exchangers** and leaches
calcium from cement‑based finishes — permanent damage. Scaling water furs up tile,
plumbing and heater elements. Preventing copper corrosion in the heat exchanger is exactly
what pushed me to build this.
- 🔄 **Live, not a one‑shot test.** The LSI is recomputed every poll from your _live_ pH and
water temperature, plus the slow‑changing chemistry you enter once (calcium hardness,
total alkalinity, cyanuric acid). You see the _current_ balance and get alerted to drift.
- ⚖ **The balanced band is deliberately asymmetric: −0.3 … +0.5** (0 ideal) — a slightly
positive value is safer, because a thin protective scale layer shields surfaces while
corrosive water does irreversible harm.
- The app classifies each reading (severe corrosive → corrosive → balanced → scaling →
severe scaling) and fires an edge‑triggered **LSI warning** Flow card with `lsi`,
`classification`, `direction` and `severity` tokens, plus an `alarm_water_balance` tile.
- Uses the Carrier closed‑form LSI with a pH‑dependent cyanuric‑acid correction (stabilised
pools handled correctly); accepts calcium/alkalinity in ppm, °dH or °f.
**Honest caveat (DIN 19643):** the LSI covers the calcium‑carbonate/CO₂ equilibrium and
metals like copper/iron and cement‑based materials — it is **not** a valid indicator for
**stainless‑steel** corrosion. That caveat is shown in‑app too.
Sources behind the band scheme and interpretation:
- ANSI/PHTA/ICC‑11 (formerly APSP‑11), _Water Quality in Public Pools and Spas_ — [https://www.phta.org/](https://www.phta.org/)
- DIN 19643, _Aufbereitung von Schwimm- und Badebeckenwasser_ (stainless‑steel caveat)
- W. F. Langelier (1936), original definition
- Orenda Technologies, _Understanding the LSI_ — [Understanding LSI: The Langelier Saturation Index](https://blog.orendatech.com/langelier-saturation-index)
- Lovibond, _Balanced Water (Langelier Index)_
LSI is **opt‑in** — enable it and enter your chemistry values when you want it.
### 🎮 Control & Flow (opt‑in)
Off by default. Enable **Control (write)** and you get control tiles + Flow actions:
- **Set pump mode** — Auto/On/Off, duration, speed stage (tile ON auto‑reverts to Auto)
- **Set light mode** / **Set DMX scene** (1–12) / **Set all lights & DMX scenes**
- **Set PV‑surplus mode**
- **Set water chemistry** (feeds the LSI from a Flow)
### ⚙ Setup
1. Install the app, add the **Pool** device.
2. Enter the controller’s host or IP (default `violet.local`). _Tip: the Violet doesn’t
advertise mDNS, so using the controller’s static IP is the most reliable._
3. Tiles appear for your detected equipment.
4. _(Optional)_ turn on **Compute LSI** + enter chemistry; _(optional)_ turn on **Control**.
### 🔒 A note on control security
Control is off by default. When enabled, writes use a controller account you provide, over
the Violet’s **plain‑HTTP** local API — so use a least‑privilege account on a trusted/
segmented network and rotate the write password before sharing configs. Reads need no
credentials.
### 🙋 Feedback / testers welcome
This is a fresh release and I’d love feedback — especially from Violet/BADU Blue owners with
different equipment combinations (solar, DMX lighting, dosing channels, overflow tanks).
Bug reports, missing readings, and Flow‑card wishes all very welcome in this thread — or as a GitHub issue: [GitHub - tnsturm/violet-homey-app · GitHub](https://github.com/tnsturm/violet-homey-app)
### 🔭 What’s next (roadmap)
This first release focuses on monitoring, the LSI safety net and basic control. Still
planned / in the works for coming versions:
- 📥 **Live alarm push** — the controller’s own alarm/error notifications pushed straight into Homey as Flow triggers.
- ☁ **PoolLab / LabCOM import** — auto‑import your slow‑changing chemistry values (calcium hardness, alkalinity, CYA) from the PoolLab cloud instead of typing them; feeds the LSI automatically.
- 🧭 **Water‑balance recommendations** — advisory help on getting your source/tap water into a good LSI band, which values are the real levers, including CO₂ out‑gassing when you top up with fresh water.
- 🎚 **Dosing & setpoints** — adjust target pH/ORP and dosing settings from Homey.
- 📈 **More sensors** — filter pressure and flow readings, plus a review of the auto‑detection.
No promises on timing — feedback in this thread will help me prioritise.
### 🤖 How this was built (entirely IDE‑free)
One meta note that might interest this community: this whole app was built **without a
traditional IDE **— start to finish in** Claude Code** in the terminal, with GitHub. I didn’t
hand‑write the application code; my part was the domain knowledge, testing on the real
controller, and the decisions. It ran as a real engineering process (spec → plan → test‑first
→ automated security review) and, along the way, grew into its own self‑verifying _agentic
development loop_.
I wrote the full story up as a separate thread — how it began, how **Superpowers** made
disciplined IDE‑free development work, and how the loop learned to run itself:
👉 [[How I built a Homey app without an IDE — with Claude Code, SuperpowersSki, and an automated development loop - Developers - Homey Community Forum](https://community.homey.app/t/how-i-built-a-homey-app-without-an-ide-with-claude-code-superpowersski-and-an-automated-development-loop/157110)]
Full source and README (setup details, LSI math, security notes) are on GitHub:
👉 [GitHub - tnsturm/violet-homey-app · GitHub](https://github.com/tnsturm/violet-homey-app)
### 📦 Version
Current App Store version: **0.4.4** (Test/beta channel). Starting certification with Athom right now.
🇩🇪 German version of this announcement ([poolsteuerung.de](http://poolsteuerung.de)): [[Violet + BADU Blue in Homey Pro – neue App mit LSI Berechnung - PoolDigital Forum](https://www.poolsteuerung.de/viewtopic.php?t=2493)]
**Homey App Store:** [https://homey.app/en-us/app/de.neunbft.violet/Violet-+-BADU-Blue-Pool-Control/](https://homey.app/en-us/app/de.neunbft.violet/Violet-+-BADU-Blue-Pool-Control/)
**Post date:** [July 15, 2026, 11:31am UTC](https://community.homey.app/t/violet-badu-blue-pool-control-for-homey/157109/2 "2026-07-15T11:31:50Z")
</div>
**Update: Violet Pool Control 0.4.7 is now live on the Homey App Store** 🎉
Athom has certified the app — it’s now publicly available, no test-channel link needed anymore: [Violet Poolsteuerung | Homey](https://homey.app/de-de/app/de.neunbft.violet/Violet-Poolsteuerung/)
And the next update (0.6.2) is already submitted to the store: the app now reads your Violet’s configuration — new input tiles (e.g. filter pressure, flow) with your own names, units and decimals, temperature sensors with your configured names and smarter auto-selection, no more ghost tiles for features disabled in the Violet, plus a fix for canister-range values reported in hours.
0.6.2 is currently available in test channel:
[Violet Poolsteuerung | Homey Test](https://homey.app/de-de/app/de.neunbft.violet/Violet-Poolsteuerung/test/)
Feedback and issue reports are very welcome!
**Post date:** [July 21, 2026, 2:31pm UTC](https://community.homey.app/t/violet-badu-blue-pool-control-for-homey/157109/3 "2026-07-21T14:31:48Z")
</div>
# Violet + BADU Blue — Quickstart Guide
This app brings your **PoolDigital Violet** or **BADU Blue** pool controller into
Homey over your local network — no cloud account, no PoolDigital login. Everything
below works the same for both; BADU Blue is Speck Pumpen’s badge of the same
PoolDigital hardware.
## Requirements
- A Homey Pro (local platform)
- Your Violet/BADU Blue controller on the same network as Homey
- Recommended: give the controller a static IP so Homey doesn’t lose it after a
router reboot
## Setting it up
1. Install the app from the [Homey App Store](https://homey.app/de-de/app/de.neunbft.violet/Violet-Poolsteuerung/).
2. Add a **Pool** device and enter the controller’s host or IP. Try `violet.local`
first; if that doesn’t resolve on your network, use the controller’s IP address
instead.
3. The device shows up with tiles for whatever equipment your controller actually
reports — no empty tiles for gear you don’t have.
4. Reading values (temperature, pH, pump state, etc.) works immediately, without
any password.
That’s it for monitoring. Two optional features go further — both are off until
you switch them on:
## Optional: the water-balance safety net
Enable **Compute LSI** in the device settings and enter your calcium hardness,
total alkalinity and cyanuric acid (from your test kit or PoolLab). The app then
continuously works out whether your water is **corrosive** , **balanced** or
**scaling** , using live pH and temperature — not just the day you last tested.
Why it matters: corrosive water attacks copper and iron parts (especially the
heater), and scaling water deposits limescale on tiles and plumbing. You get a
Homey alarm and a Flow trigger the moment the balance drifts out of range, so you
can act before either type of damage sets in.
## Optional: controlling the pool from Homey
Enable **Control (write)** in the device settings to command the pump, lights, DMX
scenes and PV-surplus mode from Homey tiles and Flow. This needs a
username/password for the controller — use a dedicated, least-privilege account,
since the Violet’s local API is plain HTTP (no encryption) on your LAN. Reading
values never needs a password, only writing commands does.
## Showing/hiding equipment tiles
Every equipment group (heater, solar, cover, backwash, water refill, overflow
tank, dosing, …) has an **Auto / Always show / Hide** setting. Auto — the
default — shows a tile only when your controller actually reports that hardware,
so your device view stays focused on what you actually have installed.
## Flow automation
Everything the app reads or does is available in Flow: triggers for LSI warnings,
dosing problems, backwash faults and overflow-tank faults; actions to set the
pump/light/DMX/PV-surplus mode and to update your water-chemistry values. Alarms
also show up automatically in the device’s alarm tiles.
## Getting alarm push notifications from the Violet
The Violet can push its own alarms straight to Homey (separate from the app’s
built-in LSI/dosing alarms above), firing an **“An alarm was received”** Flow
trigger.
To set it up:
1. In the Violet’s own notification settings, set the receiver to your Homey’s IP
address, using the **Alarm listener port** shown in the device settings
(default `22222`).
2. The Violet’s normal web interface can’t change _its own_ receiving port — that
needs an undocumented page. Open
`http://<violet-ip>/modifyParameter.htm?NOTIFY_http_baseport` in a browser,
enter the same port number there, and save. (The device settings screen in
Homey also shows this as a hint right next to the port field.)
Note: this channel has no encryption or authentication on the Violet’s side, so
keep it LAN-only — never forward that port to the internet. It only ever feeds
Homey a notification; it can’t be used to control the pool.
## Troubleshooting / FAQ
- **`violet.local` doesn’t resolve** — the Violet doesn’t advertise itself via
mDNS on every network. Use its IP address instead (and consider giving it a
static one).
- **Some tiles are missing** — that’s expected if your controller doesn’t report
that equipment; check the feature-group settings above if you expected to see
one.
- **pH/ORP/chlorine show `-` right after startup** — the app only trusts those
readings once the pump has circulated water for a bit (configurable “pump
warm-up” setting), since a stagnant sensor isn’t representative.
- **BADU Blue vs. Violet** — identical hardware, identical setup; everything in
this guide applies to both.
- Found a bug or have a feature idea? Reply in this topic.
