# Variabele vullen met een waarde van een sensor
**URL:** <https://community.homey.app/t/variabele-vullen-met-een-waarde-van-een-sensor/16534>\
**Category:** Vragen & hulp\
**Created:** [August 6, 2019, 7:15pm UTC](https://community.homey.app/t/variabele-vullen-met-een-waarde-van-een-sensor/16534 "2019-08-06T19:15:29Z")\
**Showing post:** 3
**Author:** ![FKey](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/fkey/32/14793_2.png) [@FKey](https://community.homey.app/u/FKey)\
**Post date:** [August 6, 2019, 7:58pm UTC](https://community.homey.app/t/variabele-vullen-met-een-waarde-van-een-sensor/16534/3 "2019-08-06T19:58:59Z")
Zoek eens op tags, de tag van de sensor kan je in de kaart van de variabele zetten
> [@How to use tags in a flow](https://community.homey.app/t/how-to-use-tags-in-a-flow/9285):
> How to use tags in a flow on 2.0.x There are a lot of questions about using the tags in the 2.0.x firmware of Homey. So here i give you a simple explanation of using tags in 2.0.x. We start with the WHEN part When making a flow you select a device in the WHEN part of the flow. In this example i used a Fibaro plug. When selecting the device you get the option to choose “The power changed” f.e. When clicked you will see the tag(s) coming with this card. We gonna use that tag later, no need in…
_[View the full topic](https://community.homey.app/t/variabele-vullen-met-een-waarde-van-een-sensor/16534)._
