# \[Unsupported\] Homey v2 REST API
**URL:** <https://community.homey.app/t/unsupported-homey-v2-rest-api/7268>\
**Category:** Developers\
**Created:** [January 18, 2019, 3:07pm UTC](https://community.homey.app/t/unsupported-homey-v2-rest-api/7268 "2019-01-18T15:07:04Z")\
**Showing post:** 47
**Author:** ![Lammy](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/lammy/32/11436_2.png) [@Lammy](https://community.homey.app/u/Lammy)\
**Post date:** [May 28, 2019, 6:25am UTC](https://community.homey.app/t/unsupported-homey-v2-rest-api/7268/47 "2019-05-28T06:25:08Z")
Here’s how to have your application login to homey with just your e-mail address and password (once) and obtain a refresh token for subsequent access.
Notice, the refresh token will expire, either by expiration or revocation.
There are quite a few more things to discover, but this will get you going.
In the following steps, I didn’t register a new application (probably possible, but I didn’t look into that yet), I just borrowed the client\_id and client\_secret from [developer.athom.com](http://developer.athom.com) (client\_id=598d85a330e1bb0c0d75b8eb and client\_secret=ba93fc861b204732607169fb29c2708f1da7e17f). Other combinations for client\_id and client\_secret will also work (for example homey.ink), as long as the redirect\_uri matches.
Step 1, get a JWT with your credentials.
HTTPS-POST your e-mail address and password, form-url-encoded, to [accounts.athom.com/login](http://accounts.athom.com/login).
No client\_\* needed at this time.
The JSON reply is the JWT as {“token”: “`jwt`”}
Step 2, obtain a delegation code.
HTTPS-GET [accounts.athom.com//authorise?client\_id=xxx&redirect\_uri=](http://accounts.athom.com//authorise?client_id=xxx&redirect_uri=)`uri`&response\_type=code&user\_token=`JWT from previous step`
Since I used the client\_id from [developer.athom.com](http://developer.athom.com), the `uri` in this case is the aforementioned. The redirect\_uri is important and will be checked (as it should be)
Be aware, the HTTP result will be a 302 (redirect).
The location-header contains a query parameter ‘code’. It’s value is the delegation code. The header looks like: “location: https://`redirect_uri`?code=89bc40ceXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX29”.
Step 3, get an access token
HTTPS-POST [api.athom.com/oauth2/token](http://api.athom.com/oauth2/token), form-url-encoded
Body: client\_id=XXX&client\_secret=YYY&grant\_type=authorization\_code&code=`Delegation code from previous step`
The JSON result looks like this in readable format:
“access\_token”: “51163d8xxxxxxxxxxxxxxxx8282579f8fe77ee”,
“expires\_in”: 3660,
“refresh\_token”: “f7d635axxxxxxxxxxxxxxxx1c2a258f4e33d15b”,
“token\_type”: “bearer”
Use the access\_token for the next step, but also keep the refresh\_token. You will need the refresh\_token in the future to obtain a new bearer code.
Step 4, obtain a JWT to login to your homey
HTTPS-POST [api.athom.com//delegation/token?audience=homey](http://api.athom.com//delegation/token?audience=homey)
Add an http-header: Authorization: Bearer `access_token from previous step or step 6`
The JSON result contains just the JWT.
Step 5, login to homey
HTTPS-POST `uri`/api/manager/users/login
Body: {"token”:”`JWT from step 4`”}
The reply is the desperately sought bearer token in JSON format.
`uri` can be a number of things:
- The fastest option is homey’s local IP address.
- The second is a local qualified DNS name.
- Another option is: [w-x-y-z.homey.homeylocal.com](http://w-x-y-z.homey.homeylocal.com) (w-z = the local IP address bytes).
- More options exist, all through the cloud and pretty much equally slow.
The bearer code will expire after 24 hours. To obtain a new one without user credentials, see step 6.
Step 6, refresh the bearer token
The bearer token expires every 24 hours and with good reason.
If you saved the refresh\_token from step 3, you can obtain a new access\_token and hence a new bearer token. Note: this will not go on indefinitely. At some point you will have to login again.
HTTPS-POST [api.athom.com/delegation/token?audience=homey](http://api.athom.com/delegation/token?audience=homey), form-url-encoded.
Body: client\_id=XXX&client\_secret=YYY&grant\_type=refresh\_token&refresh\_token=\<refresh\_token\>
The response is similar to the response in step 3. Use the access\_token to repeat steps 4 and 5. Keep the refresh\_token for the next refresh (The refresh\_token may change).
With the access\_token received in step 3 or 6 you can find useful information like cloud id and homey’s ip address:
HTTPS\_GET [api.athom.com/user/me](http://api.athom.com/user/me)
Add header: Authorization: Bearer \<access\_token from step 3 or 6\>
_[View the full topic](https://community.homey.app/t/unsupported-homey-v2-rest-api/7268)._
