Device information
DeviceId |bff7bae324434cd05fzhf4|
ProductId |dtzziy1e|
Missing additional features like:
- luminance (beam)
- distance.
- Log
Device specification
"device": {
"active_time": 1737732002,
"biz_type": 0,
"category": "hps",
"create_time": 1737732002,
"icon": "smart/icon/bay1646638313646AYzQ/54984f9bf40e9d65d294d7c748a6119a.png",
"id": "bff7bae324434cd05fzhf4",
"ip": "<redacted>",
"lat": "<redacted>",
"local_key": "<redacted>",
"lon": "<redacted>",
"model": "MTG275-ZB-RL",
"name": "Human presence sensor #1",
"node_id": "f84477fffe4c5a7c",
"online": true,
"owner_id": "<redacted>",
"product_id": "dtzziy1e",
"product_name": "Human presence sensor",
"status": [
"code": "presence_state",
"value": "presence"
"code": "sensitivity",
"value": 7
"code": "near_detection",
"value": 60
"code": "far_detection",
"value": 600
"code": "checking_result",
"value": "check_success"
"code": "target_dis_closest",
"value": 63
"sub": true,
"time_zone": "+01:00",
"uid": "<redacted>",
"update_time": 1737732028,
"uuid": "<redacted>"
"specifications": {
"category": "hps",
"functions": [
"type": "Integer",
"values": "{\"unit\":\"\",\"min\":1,\"max\":9,\"scale\":0,\"step\":1}"
"type": "Integer",
"values": "{\"unit\":\"m\",\"min\":0,\"max\":1000,\"scale\":2,\"step\":10}"
"type": "Integer",
"values": "{\"unit\":\"m\",\"min\":150,\"max\":1000,\"scale\":2,\"step\":10}"
"status": [
"type": "Enum",
"values": "{\"range\":[\"none\",\"presence\"]}"
"type": "Integer",
"type": "Integer",
"type": "Integer",
"type": "Enum",
"values": "{\"range\":[\"checking\",\"check_success\",\"check_failure\",\"others\",\"comm_fault\",\"radar_fault\"]}"
"type": "Integer",
"values": "{\"unit\":\"m\",\"min\":0,\"max\":1000,\"scale\":2,\"step\":1}"
"data_points": [
"custom_name": "",
"dp_id": 1,
"time": 1737732638488,
"type": "enum",
"value": "presence"
"custom_name": "",
"dp_id": 2,
"time": 1737732003957,
"type": "value",
"value": 7
"custom_name": "",
"dp_id": 3,
"time": 1737732004142,
"type": "value",
"value": 60
"custom_name": "",
"dp_id": 4,
"time": 1737732004244,
"type": "value",
"value": 600
"custom_name": "",
"dp_id": 6,
"time": 1737732004348,
"type": "enum",
"custom_name": "",
"dp_id": 9,
"time": 1737732701917,
"type": "value",
"value": 63
"code": "confirm_delay",
"custom_name": "",
"dp_id": 101,
"time": 1737732004548,
"type": "value",
"value": 10
"code": "fading_time",
"custom_name": "",
"dp_id": 102,
"time": 1737732004649,
"type": "value",
"value": 30
"code": "cli",
"custom_name": "",
"dp_id": 103,
"time": 1737732004751,
"type": "string",
"value": ""
"code": "illuminance",
"custom_name": "",
"dp_id": 104,
"time": 1737732638646,
"type": "value",
"value": 1782
"code": "trigger_sensitivity",
"custom_name": "",
"dp_id": 105,
"time": 1737732004046,
"type": "value",
"value": 5
"code": "trigger_distance",
"custom_name": "",
"dp_id": 106,
"time": 1737732004928,
"type": "value",
"value": 60
"code": "relay_mode",
"custom_name": "",
"dp_id": 107,
"time": 1737732005003,
"type": "enum",
"value": "local"
"code": "relay_state",
"custom_name": "",
"dp_id": 108,
"time": 1737732638582,
"type": "enum",
"value": "on"
"code": "running_sta",
"custom_name": "",
"dp_id": 109,
"time": 1737732005150,
"type": "enum",
"value": "off"
"code": "illumin_threshold",
"custom_name": "",
"dp_id": 110,
"time": 1737732005221,
"type": "value",
"value": 0
"code": "relay_polarity",
"custom_name": "",
"dp_id": 111,
"time": 1737732005292,
"type": "enum",
"value": "open"
"code": "block_time",
"custom_name": "",
"dp_id": 112,
"time": 1737732005366,
"type": "value",
"value": 25
"code": "param_result",
"custom_name": "",
"dp_id": 113,
"time": 1737732005436,
"type": "enum",
"value": "none"
"code": "resfacset",
"custom_name": "",
"dp_id": 114,
"time": 1737732002102,
"type": "enum",
"value": "reset_setting"
"code": "sensor_ctrl",
"custom_name": "",
"dp_id": 115,
"time": 1737732005511,
"type": "enum",
"value": "no"
