Tuya Smart > Nedis GU10 Color spot issues
Nedis GU10 color spot not supporing “moods” in Homey
Homey version
Which Homey are you using and with which firmware?
Homey Pro 2019 12.3.0
Tuya app version
Which Tuya app version do you have installed on your Homey?
Tuya Smart 6.2.0
App diagnostics report ID
Please generate an app diagnostics report and share it identifier
63a9748a-4fb4-45f1-82f6-ef5bbea545e7
Description
Tell us what isn’t working for you: please try to be as descriptive as possible.
When installed it does not support light “moods” in Homey.
And shows up as a motion sensor in settings??
Device specification
  "device": {
    "active_time": 1737733213,
    "biz_type": 0,
    "category": "dj",
    "create_time": 1737733213,
    "icon": "smart/icon/bay1642163404342eZ2o/1657876378526499754bc.png",
    "id": "bf62c28e9de98d5ec4rjas",
    "ip": "<redacted>",
    "lat": "<redacted>",
    "local_key": "<redacted>",
    "lon": "<redacted>",
    "model": "ZBLC10GU10",
    "name": "Nedis Gu10 #4",
    "node_id": "a4c138d03274b762",
    "online": true,
    "owner_id": "<redacted>",
    "product_id": "bzj8symz",
    "product_name": "Smart Light",
    "status": [
        "code": "switch_led",
        "value": true
        "code": "work_mode",
        "value": "white"
        "code": "bright_value_v2",
        "value": 1000
        "code": "temp_value_v2",
        "value": 1000
        "code": "colour_data_v2",
        "value": "{\"h\":0,\"s\":1000,\"v\":1000}"
        "code": "scene_data_v2",
        "value": "{\"scene_num\":1,\"scene_units\":[{\"bright\":248,\"h\":0,\"s\":33,\"temperature\":1,\"unit_change_mode\":\"jump\",\"unit_gradient_duration\":0,\"unit_switch_duration\":0,\"v\":32}]}"
        "code": "countdown_1",
        "value": 0
        "code": "control_data",
        "value": ""
        "code": "rhythm_mode",
        "value": "AAAAAAA="
        "code": "sleep_mode",
        "value": "AAA="
        "code": "wakeup_mode",
        "value": "AAA="
    "sub": true,
    "time_zone": "+01:00",
    "uid": "<redacted>",
    "update_time": 1737733422,
    "uuid": "<redacted>"
  "specifications": {
    "category": "dj",
    "functions": [
        "type": "Boolean",
        "values": "{}"
        "type": "Enum",
        "values": "{\"range\":[\"white\",\"colour\",\"scene\",\"music\"]}"
        "type": "Integer",
        "values": "{\"min\":10,\"max\":1000,\"scale\":0,\"step\":1}"
        "type": "Integer",
        "values": "{\"min\":0,\"max\":1000,\"scale\":0,\"step\":1}"
        "type": "Json",
        "values": "{\"h\":{\"min\":0,\"scale\":0,\"unit\":\"\",\"max\":360,\"step\":1},\"s\":{\"min\":0,\"scale\":0,\"unit\":\"\",\"max\":1000,\"step\":1},\"v\":{\"min\":0,\"scale\":0,\"unit\":\"\",\"max\":1000,\"step\":1}}"
        "type": "Json",
        "values": "{\"scene_num\":{\"min\":1,\"scale\":0,\"max\":8,\"step\":1},\"scene_units\": {\"unit_change_mode\":{\"range\":[\"static\",\"jump\",\"gradient\"]},\"unit_switch_duration\":{\"min\":0,\"scale\":0,\"max\":100,\"step\":1},\"unit_gradient_duration\":{\"min\":0,\"scale\":0,\"max\":100,\"step\":1},\"bright\":{\"min\":0,\"scale\":0,\"max\":1000,\"step\":1},\"temperature\":{\"min\":0,\"scale\":0,\"max\":1000,\"step\":1},\"h\":{\"min\":0,\"scale\":0,\"unit\":\"\",\"max\":360,\"step\":1},\"s\":{\"min\":0,\"scale\":0,\"unit\":\"\",\"max\":1000,\"step\":1},\"v\":{\"min\":0,\"scale\":0,\"unit\":\"\",\"max\":1000,\"step\":1}}}"
        "type": "Integer",
        "values": "{\"unit\":\"s\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1}"
        "type": "Json",
        "values": "{\"change_mode\":{\"range\":[\"direct\",\"gradient\"]}, \"bright\":{\"min\":0,\"scale\":0,\"unit\":\"\",\"max\":1000,\"step\":1}, \"temperature\":{\"min\":0,\"scale\":0,\"unit\":\"\",\"max\":1000,\"step\":1}, \"h\":{\"min\":0,\"scale\":0,\"unit\":\"\",\"max\":360,\"step\":1},\"s\":{\"min\":0,\"scale\":0,\"unit\":\"\",\"max\":255,\"step\":1},\"v\":{\"min\":0,\"scale\":0,\"unit\":\"\",\"max\":255,\"step\":1}}"
        "type": "Raw",
        "values": "{\"maxlen\":255}"
        "type": "Raw",
        "type": "Raw",
    "status": [
        "type": "Boolean",
        "values": "{}"
        "type": "Enum",
        "type": "Integer",
        "type": "Integer",
        "type": "Json",
        "type": "Json",
        "type": "Integer",
        "type": "Json",
        "type": "Raw",
        "values": "{\"maxlen\":\"255\"}"
        "type": "Raw",
        "type": "Raw",
  "data_points": [
      "custom_name": "",
      "dp_id": 1,
      "time": 1737733214396,
      "type": "bool",
      "value": true
      "custom_name": "",
      "dp_id": 2,
      "time": 1737733214477,
      "type": "enum",
      "value": "white"
      "code": "bright_value",
      "custom_name": "",
      "dp_id": 3,
      "type": "value",
      "value": 1000
      "code": "temp_value",
      "custom_name": "",
      "dp_id": 4,
      "type": "value",
      "value": 1000
      "code": "colour_data",
      "custom_name": "",
      "dp_id": 5,
      "type": "string",
      "value": "000003e803e8"
      "code": "scene_data",
      "custom_name": "",
      "dp_id": 6,
      "time": 1737733226508,
      "type": "string",
      "value": "0000000100000021002000f80001"
      "code": "countdown",
      "custom_name": "",
      "dp_id": 7,
      "time": 1737733226443,
      "type": "value",
      "value": 0
      "custom_name": "",
      "dp_id": 9,
      "time": 1737733213690,
      "type": "string",
      "value": ""
      "custom_name": "",
      "dp_id": 30,
      "time": 1737733227276,
      "type": "raw",
      "value": "AAAAAAA="
      "custom_name": "",
      "dp_id": 31,
      "time": 1737733227185,
      "type": "raw",
      "value": "AAA="
      "custom_name": "",
      "dp_id": 32,
      "time": 1737733227063,
      "type": "raw",
      "value": "AAA="
A post was merged into an existing topic: [APP] Tuya - Connect any Tuya device with Homey (by Tuya Inc. / Athom)
Please ask in the appropriate topic as linked in the App store, or use the search to centralize questions about a specific App or device/brand.
Therefore the post is moved into the appropriate topic, closed and will be automatically deleted in 7 days to keep the forum clean as possible. If you have any problems with that please feel free to contact me or another moderator.
