I am a happy user of the trashcan reminder app but the last weeks it doesnt work anymore…
Am I the only one with this problem?
I have restart the app en restart homey.
In settings I have data in the debug part:
You get the exclamation if the condition is not met, if there’s no garbage collected today. If you inverse the cards, I expect them to give green checkmarks.
Same issue here, the app always returns that nothing is collected today.
I’m using the DeAfvalApp, can see the list with all collection dates for the entire year.
So the data seems fine, it’s just the data parsing that goes wrong.
Since a few months, the app does not give me any reminders anymore.
I have linked with RD4 and the app indicates I have a valid address.
In the settings info inside the app I can see pickup dates for various kinds of trash, for example today and tomorrow.
However the flow cards don’t allow me to show any sensible reminders.
As an example, I trigger every day, filter on ‘trash to collect Tomorrow / Any type’ and then post a notification. This does not delivery any results anymore.
When I chat with Homey, the device indicates the next trash is collected in 366 days , where, according to the data in the setup page of the App, today and tomorrow (e.g. 17.9.2020 and 18.9.2020) GFT and PMD is collected.
Could there be a bug or is it me? Seems like a parsing issue with the ‘year’ value.
Thanks…
I tested the app by manually adding tomorrow’s date.
When the date is added manually, the date format is YYYY-MM-DD but my automatic RD4 delivered data is DD-MM-YYYY format.
When tomorrow’s date is recorded in the debug info as “2020-09-22” then the App works.
When tomorrow’s date is recorded in the debug info as “22-09-2020” then the App does not work.
I suspect the date format is the cause of the issue.
Since version 3.07 and 3.08 the garage collection for gemeente Hellendoorn does not work anymore. I get unkown address now. The API is not changed or anything, because other systems such as afvalwijzer (HA) are still working.
I also tried the API’s using Postman and its still working fine.
Problem is, that the Gemeente Hellendoorn afval app uses the url/FQDN: wasteapi.ximmio.com. I checked this with the IOS app and this is the url its using. This url is also working in Postman.
