# TKB Home TZ74 double relay switch
**URL:** <https://community.homey.app/t/tkb-home-tz74-double-relay-switch/29636>\
**Category:** Devices\
**Created:** [May 10, 2020, 11:41am UTC](https://community.homey.app/t/tkb-home-tz74-double-relay-switch/29636 "2020-05-10T11:41:21Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![nadtom](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/nadtom/32/18363_2.png) [@nadtom](https://community.homey.app/u/nadtom)\
**Post date:** [May 10, 2020, 11:41am UTC](https://community.homey.app/t/tkb-home-tz74-double-relay-switch/29636/1 "2020-05-10T11:41:21Z")
</div>
The Homey cannot see the two channel’s of TKB Home TZ74 double relay switch. Homey can see as a single relay switch, so works only one channel. Do you have a similar problem/experience? Is any solution? Thanky you!
**Author:** ![Caseda](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/caseda/32/138695_2.png) [@Caseda](https://community.homey.app/u/Caseda)\
**Post date:** [May 10, 2020, 12:31pm UTC](https://community.homey.app/t/tkb-home-tz74-double-relay-switch/29636/2 "2020-05-10T12:31:19Z")
</div>
It will not be 1 device with 2 switches, but will be 3 separate devices, the main device (needed for settings) and it’s both outputs, so you are most likely looking over the 2 output devices in your Homey.
I can not test this as i don’t have the device, and i was not the 1 adding it to the app, it was added by another community member.
**Post date:** [May 10, 2020, 12:53pm UTC](https://community.homey.app/t/tkb-home-tz74-double-relay-switch/29636/3 "2020-05-10T12:53:30Z")
</div>
Thank you it’s a good news.🍻
