# Somfy IO always requires Tahoma or Connexxoon
**URL:** <https://community.homey.app/t/somfy-io-always-requires-tahoma-or-connexxoon/82849>\
**Category:** Ideas & Suggestions\
**Tags:** homey-pro\
**Created:** [June 22, 2023, 6:34am UTC](https://community.homey.app/t/somfy-io-always-requires-tahoma-or-connexxoon/82849 "2023-06-22T06:34:29Z")\
**Showing post:** 14
**Post date:** [August 24, 2023, 9:25pm UTC](https://community.homey.app/t/somfy-io-always-requires-tahoma-or-connexxoon/82849/14 "2023-08-24T21:25:13Z")
> [@robertklep](#):
> Doesn’t look like it does
Hmmm 🤔 😉
It does, Robert, according to Adrian, for devices which support it:
> [@\[APP\]\[Cloud & Pro\] Somfy Tahoma & Connexoon (v4.0.106, test v4.0.122)](https://community.homey.app/t/app-cloud-pro-somfy-tahoma-connexoon-v4-0-106-test-v4-0-122/35206/1):
> **Local Access**
> Tahoma and Connexoon now support local access when using a Homey Pro. To enable this you need to switch on the Developer mode in you **Somfy account** :
> First connect to the Somfy website and navigate to the 👨 **My Account** menu.
> Find the different available options for your TaHoma box and activate **Developer Mode**.
> Once developer mode is activated, your Tahoma box will start sending mDNS data advertising it’s IP address. The app will detect that and setup a local connection automatically, so you don’t need to do anything on your Homey Pro to use it. All you existing devices that are supported by direct connection will start using the local access to Tahoma.
> **Note** : not all devices are supported by the local connection, but don’t worry as the Homey app will still access those via the Somfy cloud.
The Somfy Connectivity Kit indeed is cloud only.
_[View the full topic](https://community.homey.app/t/somfy-io-always-requires-tahoma-or-connexxoon/82849)._
