# Smoke detectors and sirens
**URL:** <https://community.homey.app/t/smoke-detectors-and-sirens/29021>\
**Category:** Devices\
**Tags:** z-wave\
**Created:** [April 27, 2020, 1:03pm UTC](https://community.homey.app/t/smoke-detectors-and-sirens/29021 "2020-04-27T13:03:02Z")\
**Posts on this page:** 11\
**Page:** 1
<div class="post-metadata">
**Author:** ![pixel](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/pixel/32/18365_2.png) [@pixel](https://community.homey.app/u/pixel)\
**Post date:** [April 27, 2020, 1:03pm UTC](https://community.homey.app/t/smoke-detectors-and-sirens/29021/1 "2020-04-27T13:03:02Z")
</div>
I have a couple of Fibaro Smoke detectors at home. In case of an alarm I was hoping the smoke detectors could alarm each other and have all sirens go off.
Although when setting up a flow there’s no way to choose a “then action” for the smoke detector. Is this because they are battery powered and not polling statuses that often?
What options do I have? Buy extra sirens? Use Sonos speakers (are they reliable in case of fire)?
**Author:** ![Osorkon](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/osorkon/32/43026_2.png) [@Osorkon](https://community.homey.app/u/Osorkon)\
**Post date:** [April 27, 2020, 1:08pm UTC](https://community.homey.app/t/smoke-detectors-and-sirens/29021/2 "2020-04-27T13:08:26Z")
</div>
> [@pixel](#):
Exactly. What you need if battery powered is a FLIRs Device.
**Post date:** [April 27, 2020, 1:14pm UTC](https://community.homey.app/t/smoke-detectors-and-sirens/29021/3 "2020-04-27T13:14:24Z")
</div>
Hmm, OK. I tried Google it but couldn’t find much. What is it? Software or hardware? Is it compatible with Fibaro smoke detectors?
**Post date:** [April 27, 2020, 1:29pm UTC](https://community.homey.app/t/smoke-detectors-and-sirens/29021/4 "2020-04-27T13:29:59Z")
</div>
**FLiRS (Frequently Listening Receiver Slave)**
> **[Z-Wave-FLiRS.pdf](https://www.silabs.com/documents/login/white-papers/Z-Wave-FLiRS.pdf)**
> 483.37 KB
**Author:** ![Caseda](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/caseda/32/138695_2.png) [@Caseda](https://community.homey.app/u/Caseda)\
**Post date:** [April 27, 2020, 5:14pm UTC](https://community.homey.app/t/smoke-detectors-and-sirens/29021/5 "2020-04-27T17:14:49Z")
</div>
What you are trying to achieve is not possible as fibaro smoke sensors are asleep 99.9% of the time to send signals by other devices.
This has been answered several times already on the forum.
There is currently only 1 brand that made smoke sensors with flirs (what osorkorn is talking about) that I know of at least (I did forget the brand though 🤔)
**Author:** ![Igy](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/igy/32/22144_2.png) [@Igy](https://community.homey.app/u/Igy)\
**Post date:** [April 29, 2020, 11:12am UTC](https://community.homey.app/t/smoke-detectors-and-sirens/29021/6 "2020-04-29T11:12:23Z")
</div>
> [@pixel](#):
You can use siren (battery or main powered), but battery siren is not so reliable in my case (Vision siren), because it drains batteries quite quickly. If you have Sonos, then playing Soundboard sound over it is possible as well. You can use also google assistant to play message (Homey TTS app), or another option to use regular main powered regular siren and connect zwave relay to it, to trigger it when needed.
**Author:** ![TedTolboom](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/tedtolboom/32/12081_2.png) [@TedTolboom](https://community.homey.app/u/TedTolboom)\
**Post date:** [April 29, 2020, 11:19am UTC](https://community.homey.app/t/smoke-detectors-and-sirens/29021/7 "2020-04-29T11:19:38Z")
</div>
@pixel I am currently adding support for this smoke sensor:
[https://www.robbshop.nl/z-wave-rook-en-co-melder-met-sirenefunctie-robb-smarrt](https://www.robbshop.nl/z-wave-rook-en-co-melder-met-sirenefunctie-robb-smarrt)
Which is battery powered (3x CR123A), but the Siren can also be triggered manually (my ears still hurt from doing this test for your guys)…
Nice thing about this sensor is that it is also possible to link them, where if one of the alarms is triggered (smoke, heat or CO), a english voice prompt will indicate where the alarm is triggered.
**Post date:** [April 29, 2020, 11:24am UTC](https://community.homey.app/t/smoke-detectors-and-sirens/29021/8 "2020-04-29T11:24:34Z")
</div>
WOW! 😮 The Price of 189 it’s € or RMB? 😀
**Post date:** [April 29, 2020, 12:55pm UTC](https://community.homey.app/t/smoke-detectors-and-sirens/29021/9 "2020-04-29T12:55:20Z")
</div>
All CO sensors (z-wave) are expensive, so not that weird.
**Post date:** [April 29, 2020, 4:16pm UTC](https://community.homey.app/t/smoke-detectors-and-sirens/29021/10 "2020-04-29T16:16:17Z")
</div>
Thanks for the answers! I’m aiming towards buying dedicated and powered sirens.
However, as I already have Sonos, is there anyone here with experience about that? Any recommended setup and trigger? Are they reliable? Can you trust them to 99% that they will override any current playlist (so it’s not queued or something like that).
**Post date:** [April 29, 2020, 8:48pm UTC](https://community.homey.app/t/smoke-detectors-and-sirens/29021/11 "2020-04-29T20:48:20Z")
</div>
Unless Homey will fail, or your wifi will fail, Sonos should work. I tested it now, and it plays the soundboard sound nicely (changed automatically from TV source and returned back).
