# Setup na wifi verandering
**URL:** <https://community.homey.app/t/setup-na-wifi-verandering/58796>\
**Category:** 🇳🇱 Nederlands (Dutch)\
**Created:** [January 20, 2022, 8:01pm UTC](https://community.homey.app/t/setup-na-wifi-verandering/58796 "2022-01-20T20:01:18Z")\
**Showing post:** 3
**Post date:** [January 20, 2022, 10:36pm UTC](https://community.homey.app/t/setup-na-wifi-verandering/58796/3 "2022-01-20T22:36:09Z")
Je kunt je nieuwe wifi de SSID + wachtwoord van de oude geven. Dan moet Homey weer kunnen verbinden. (Homey wel ‘normaal’ opstarten dan)
Of:
> [@Problems connecting your new Homey Pro to your WiFi? Try this!](https://community.homey.app/t/problems-connecting-your-new-homey-pro-to-your-wifi-try-this/10161):
> Make sure your WiFi is using the 2.4 GHz network. Make sure your WiFi uses the b / g standard, only n or ac does not work. Turn off your Homey. Restart your Router and any Access Points that distribute IP addresses. Start your Homey again. If the above do not work, turn off 5 GHz WiFi and support for n and ac in your Router / Access Point during Homey installation. Ensure that your SSID (the name of your WiFi) does not use characters other than numbers and letters - do not us…
_[View the full topic](https://community.homey.app/t/setup-na-wifi-verandering/58796)._
