# Setting up simple GET request and storing value as numeric logic object
**URL:** <https://community.homey.app/t/setting-up-simple-get-request-and-storing-value-as-numeric-logic-object/48614>\
**Tags:** tools, flow\
**Created:** [June 20, 2021, 11:46am UTC](https://community.homey.app/t/setting-up-simple-get-request-and-storing-value-as-numeric-logic-object/48614 "2021-06-20T11:46:20Z")\
**Author:** ![Kongedam](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/kongedam/32/35807_2.png) [@Kongedam](https://community.homey.app/u/Kongedam)\
**Post date:** [June 21, 2021, 3:16pm UTC](https://community.homey.app/t/setting-up-simple-get-request-and-storing-value-as-numeric-logic-object/48614/2 "2021-06-21T15:16:35Z")
Maybe this post can lead you in the right direction
> [@Storing JSON data back from a POST request](https://community.homey.app/t/storing-json-data-back-from-a-post-request/9551/2):
> Have solved my problem with the awesome help from @robertklep over on the Slack channel For the HTTP request cards, you can specify advanced options in the URL box - and the gold was that you can include the payload/body as a json in that url string. So what I’ve done is: 1 flow that does the web service call - using a GET JSON trigger object. Using advanced options you enter the full string into the url field - so in my case I needed to do a POST and therefore the url field was: {“method”:“…
> [@Calling an external service and receiving the Response in a variable?](https://community.homey.app/t/calling-an-external-service-and-receiving-the-response-in-a-variable/12445/13):
> Hi all, Sorry for this delayed response, but I had to find some time for it. There are several ways to build the flows @Jef_van_Leeuwen requested. Because he wants to map multiple values from the same HTTP response it’s best to make 2 flows with combine cards GET JSON trigger object (A24), JSON object (T81) and JSONpath Better Logic (A80). (Native Homey logic support is in development, but for now we rely on BetterLogic for storing variables). When in doubt validate your JSON values for fl…
_[View the full topic](https://community.homey.app/t/setting-up-simple-get-request-and-storing-value-as-numeric-logic-object/48614)._
