# Replacing Philips Hue, Aqara, and Tado bridges with Homey
**URL:** <https://community.homey.app/t/replacing-philips-hue-aqara-and-tado-bridges-with-homey/129713>\
**Tags:** homey-pro-mini\
**Created:** [January 3, 2025, 7:17pm UTC](https://community.homey.app/t/replacing-philips-hue-aqara-and-tado-bridges-with-homey/129713 "2025-01-03T19:17:34Z")\
**Post date:** [January 3, 2025, 8:10pm UTC](https://community.homey.app/t/replacing-philips-hue-aqara-and-tado-bridges-with-homey/129713/2 "2025-01-03T20:10:40Z")
> [@\_Meligste](#):
> - a bridge (I’ve got a rather large concrete house, so that bridge will help network coverage)
It depends on the protocol used. Mains powered Zigbee & z-wave devices have a built-in router functionality; when you build your [mesh network](https://support.homey.app/hc/en-us/articles/10374465562652-Creating-a-stable-Zigbee-network-with-Homey-Pro-Early-2023), you can cover quite some space.
Only if you want to relay 433MHz, IR or Ble signals a bridge might be useful.
But [Broadlink RM4 Pro](https://duckduckgo.com/?q=Broadlink+rm&t=euandroid&ia=web) also is, not sure about Ble though.
> [@\_Meligste](#):
> replace my Philips Hue bridge, my Aqara bridge and the Tado-bridge?
From what I’ve read Hue zigbee is very stable, Homey doesn’t seem to bw able to create a rock solid zigbee controller (maybe it’s better with the mini Pro, but that’s only to find out when it’s released.)
Also light effects are very minimal, or a lot of work to create, compared to Hue’s possibilities.
With tado-_ **X** _, you don’t need a tado bridge, tado-X is Matter enabled;
but with tado-V3 a tado bridge is mandatory, for Homey to connect with the tado cloud.
About Aqara, I’d keep it when you own it already:
Most Aqara devices work via zigbee.
That requires the Aqara or Xiaomi Mi app. But do first take a look in the app store to check which devices are supported as zigbee devices: [Aqara App for Homey | Homey](https://homey.app/a/com.xiaomi-mi/)
and
[Xiaomi Mi Home App for Homey | Homey](https://homey.app/a/com.xiaomi-miio/)
Using an Aqara hub with Matter support, Aqara-supported devices become available as Matter devices, for which you don’t need a Homey app.
See also:
> **[Aqara Releases Details around its First Matter-compatible Devices - Aqara](https://www.aqara.com/en/news/aqara-releases-details-around-its-first-matter-compatible-devices/)**
> Aqara, a leading provider for smart home products, shares its latest plan of Matter support and integration for its existing and new devices. Aqara is fully
Other devices like the FP2 presence sensor and doorbell work via Wifi again, and then the [APP][Pro] HomeKit Controller for Homey (NL) app comes into play
[Source](https://community.homey.app/t/aquara-aansturen-met-homey-pro-2023/123852/5)
_[View the full topic](https://community.homey.app/t/replacing-philips-hue-aqara-and-tado-bridges-with-homey/129713)._
