# Probleme mit Tuya Cloud
**URL:** <https://community.homey.app/t/probleme-mit-tuya-cloud/83688>\
**Category:** Fragen & Hilfe\
**Created:** [July 1, 2023, 2:54pm UTC](https://community.homey.app/t/probleme-mit-tuya-cloud/83688 "2023-07-01T14:54:41Z")\
**Post date:** [July 1, 2023, 8:23pm UTC](https://community.homey.app/t/probleme-mit-tuya-cloud/83688/2 "2023-07-01T20:23:12Z")
Es ist auf Englisch, ich hoffe, das ist kein großes Problem
> [@\[APP\]\[Pro\] Tuya Cloud - This app allows you to connect Homey to the Tuya cloud](https://community.homey.app/t/app-pro-tuya-cloud-this-app-allows-you-to-connect-homey-to-the-tuya-cloud/21313/1325):
> Maybe this vid makes things a bit clearer.
> It’s pointed at Home Assistant, but the only difference is the login screen on Homey or Home Assistant.
> ![](https://us1.discourse-cdn.com/flex025/uploads/athom/original/3X/5/9/59ae58ab31d62c2186b757b99275fe34853e5634.jpeg "New Tuya Home Assistant Integration // Quick Set up Guide")
> [New Tuya Home Assistant Integration // Quick Set up Guide](https://www.youtube.com/watch?v=y6kNHIYcJ5c)
> (just found it on YT, I’m not affiliated in any way)
Offiziell app topic mit ‘how-to’
> [@\[APP\]\[Pro\] Tuya Cloud - This app allows you to connect Homey to the Tuya cloud](https://community.homey.app/t/app-pro-tuya-cloud/21313):
> Tuya Cloud app NOTE: This app is no longer actively maintained, only PR (Pull Requests) will be merged and published as update; The developer does not respond to questions / requests any longer. Alternative Tuya wifi apps You might want to migrate to the now available ‘official’ [Tuya app](https://homey.app/a/com.tuya2/). Or, when you prefer cloudless (= not internet dependent) control for your mains powered Tuya wifi devices, you’d check the [Tuya Local community app](https://homey.app/a/com.tuyalocal/test/) → no tricky firmware flash stuff involved (!) App …
_[View the full topic](https://community.homey.app/t/probleme-mit-tuya-cloud/83688)._
