# Poolthermometer
**URL:** <https://community.homey.app/t/poolthermometer/112993>\
**Category:** Devices\
**Tags:** homey-pro\
**Created:** [July 16, 2024, 5:18pm UTC](https://community.homey.app/t/poolthermometer/112993 "2024-07-16T17:18:46Z")\
**Post date:** [July 16, 2024, 6:06pm UTC](https://community.homey.app/t/poolthermometer/112993/2 "2024-07-16T18:06:15Z")
> **[ICO](https://homey.app/en-nl/app/com.ondilo.ico/ICO/)**
> Simplify your pool maintenance
> **[Flipr](https://homey.app/en-nl/app/com.goflipr/Flipr/)**
> Finally enjoy your swimming pool
> **[WN36 Pool Thermometer](https://shop.ecowitt.com/products/wn36?variant=42363921596578)**
> Features Poolthermometer with an anchor. None opening design with ultrasonic body welding: IP68 waterproof. Idle mode for further powerreduction (keep pressing the button for 8 seconds). Minimum operating lifetime: 3 years....
> **[WN34D Wider Measurement Range Temperature Sensor with 1M Silicone Cabl](https://shop.ecowitt.com/products/wn34d)**
> Waterproof and LCD Display: Water proof thermometer probe sensor with LCD display so that you can view temperature data easily. Perfect for measuring any wet temperature medium, such as swimming pool, spa, freezers, and refrigerators. High Accuracy:...
> **[WN34L Temperature Sensor with 3M PVC Cable](https://shop.ecowitt.com/products/wn34l)**
> Waterproof and LCD Display: Water proof thermometer probe sensor with LCD display so that you can view temperature data easily. Water resistant sensor features a 10-foot water proof probe, perfect for measuring any wet temperature medium, such as...
The first two devices ICO and Flipr are actually intended to check the water quality, but also measure the temperature.
The Ecowitt WN63 Pool Thermostat is designed for pools, as the name suggests. It’s not separate listed in the Homey [Misol and Ecowitt](https://homey.app/en-nl/app/com.misol/Misol-and-Ecowitt/test/) App in the App Store, but according to this discussion in the App topic ([Link](https://community.homey.app/t/app-pro-misol-and-ecowitt-release-0-1-39-test-0-1-40/47076/62)) it seems to work already.
The other two Ecowitt temperature sensors are not specific for pools, but they have a probe so that the probe can easily be placed in the water, while the batterie powered main device can be mounted outside of the pool. The WN34L seems to be listed in the App Store, the WN34D not. However, as it’s just also a temperature sensor, it’s probably also supported by the App.
What I don’t know is if the probes are also suitable for chlorinated water.
An additional gateway is required for all Ecowitt sensors, however. Please check yourself which gateway is required and if it’s supported by the Homey Misol and Ecowitt App.
_[View the full topic](https://community.homey.app/t/poolthermometer/112993)._
