I am new to Homey and in the process of adding all my devices to it. I encountered some problems but most of them I can solve on my own. My biggest problem is to add the Philips Hue bridge and all attached bulbs (Philips and Ikea Tradfre) to the Homey. I cannot find the bridge in the Philips Hue app nor in the Philips zigbee app. I want all the bulbs to be available in homey but also via the philips bridge as I use other products that can only connect to the bridge. Further I have all the lamps already connected through the bridge and dont want to go through the process of connecting them again.
Please let me know how to import all the bulbs (and if possible all the accessoires) as well.
The bridge doesn’t show up. Go to devices, ad a device, choose your app and you get noticed which bridge has been discovered. After that you get the bulbs you want
Edit: you first have to chose the sort off device you want to add.
Thanx for the reply, however I dont understand what you mean.
In homey app in android I go to apparaten, then I click the little + sign at the top right, It asks me to Chose a brand, I go to search at the bottom and philips hue. Then it says chose a device. I have the choice of sensor, dimmer switch, lamp, plug, or tap. So where is the bridge?
Just another question - really sorry but it is due to total lack of any documentation or manuals -
How can i group different lamps together so for instance 3 spots to switch them on / off together?
You have different options. You can use devices
or you can set at the IF part the LOGIC card exactly. At the exactly section fill in the room where the bulbs are.
Or you can use the Group app from Jamie Peake in the appstore.
If you connected the lights with the hue bridge.
I would prefer to group the lights in the hue app.
Then you can add the light group as an single light through the hue app to homey.
Thanks for the response. I think I stick with the Group app, however disadvantage of all these options is the inability to set the dim percentage. The lights will therefor be at the dim state they were when last turned on by the hue bridge, in fact it is only half of the solution I am looking for.
There are possibilities, you just have to find which suit you the most. This THEN part is example for my livingroom
You have to take your time for Homey, it is not an out off the box working device. If you do not invest in Homey it probably will not work the way you want.
