# LG WebOs does not work
**URL:** <https://community.homey.app/t/lg-webos-does-not-work/131929>\
**Category:** Apps\
**Tags:** app, flow\
**Created:** [March 3, 2025, 5:31am UTC](https://community.homey.app/t/lg-webos-does-not-work/131929 "2025-03-03T05:31:34Z")\
**Showing post:** 6
**Author:** ![Marius\_Stensrod](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/marius_stensrod/32/56540_2.png) [@Marius\_Stensrod](https://community.homey.app/u/Marius_Stensrod)\
**Post date:** [March 4, 2025, 8:16pm UTC](https://community.homey.app/t/lg-webos-does-not-work/131929/6 "2025-03-04T20:16:07Z")
@melectro , if you are using a Homey Pro version, I would suggest to try the app “WebOS Plus”, you can install it using CLI.
The app can be found here:
> **[GitHub - MaxvandeLaar/homey-webos-plus: Improved LG WebOS integration for Homey](https://github.com/MaxvandeLaar/homey-webos-plus)**
How to install using CLI is described here:
> [@\[HOW TO\] CLI install method](https://community.homey.app/t/how-to-cli-install-method/198):
> Homey Pro only!!! It does not work this way with Homey (cloud), it only supports CLI run which is there only for development purposes. Installing Node.js Check Node.js version on Homey: Homey App: Settings - General - About - Node.js version Download Node.js (use Homey’s version or higher) from [https://nodejs.org/](https://nodejs.org/) and install it on your computer. Download the app you want to install from GitHub Go to the repository on [GitHub](https://github.com/) (the correct link for the app you want to install is at the bottom…
_[View the full topic](https://community.homey.app/t/lg-webos-does-not-work/131929)._
