# Is it possible to add aqara devices in homey and in aqara hub?
**URL:** <https://community.homey.app/t/is-it-possible-to-add-aqara-devices-in-homey-and-in-aqara-hub/27005>\
**Tags:** app, zigbee\
**Created:** [March 11, 2020, 11:13am UTC](https://community.homey.app/t/is-it-possible-to-add-aqara-devices-in-homey-and-in-aqara-hub/27005 "2020-03-11T11:13:40Z")\
**Showing post:** 6
**Author:** ![Henk\_Renting](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/henk_renting/32/87634_2.png) [@Henk\_Renting](https://community.homey.app/u/Henk_Renting)\
**Post date:** [January 9, 2025, 10:56am UTC](https://community.homey.app/t/is-it-possible-to-add-aqara-devices-in-homey-and-in-aqara-hub/27005/6 "2025-01-09T10:56:51Z")
You can add several Aqara devices to a Xiaomi hub and then add that hub to Homey so it’s devices become available in homey too.
But:
1. You will have to use a Xiaomi hub and therefor the Xiaomi phone app on your phone to control it
2. Only some hubs are supported. I use the one with partnumber DGNWG02LM.
3. The developer of the app you have to use ([link](https://homey.app/en-gb/app/com.xiaomi-miio/Xiaomi-Mi-Home/)) is ending his support for now. The app will continue to work though; see [here](https://community.homey.app/t/app-pro-xiaomi-mi-home-app/118/1769).
4. Not all Aqara devices are supported, see a list [here](https://github.com/shaarkys/com.xiaomi-miio/wiki/Supported-Devices). The Aqara Water Leak Sensor sensor\_wleak.aq1 is listed as supported.
5. No guarantees
It’s a bit of work and you will require an additional hub if the one you have now is not supported. The DGNWG02LM I have doesn’t have to be expensive though and is probably also available second-hand. But it might be your best shot at having the device available in both Homey and another hub/environment
But why do you want the device in both environments?
(The above is also a way to connect Aqara/Xiaomi Zigbee devices over LAN to your Homey)
_[View the full topic](https://community.homey.app/t/is-it-possible-to-add-aqara-devices-in-homey-and-in-aqara-hub/27005)._
