It is working ![]()
It functions over here as well, but updating of any of the variables (numeric and status indicators such as boiler status, burner status etc.) sometimes lags for a few minutes. This makes it useless in some of the flows in which Iβd like to use it as a trigger.
Does anyone else encounter the same issue?
I use it with a Tado thermostat (icw Tado radiator valves for zone control), but the modulating behavior is quite crude with big steps. I have seen much better modulation with other thermostats.
But the modulation is triggert and start from your case the Tado thermostat. The gateway is only a gateway and function as a comunication device from the burner (Intergas) and the cloud. In my case it is pretty fast and see a change in 10 seconds or so
Yes, I understand. It was just to elaborate on the modulating behavior of the Tado which is below par.
My gateway laggs considerably.
Hello, is there a possibility that the Intergas xtend also will be visible?
hello is there a possibility for an update so that you can also see the intergas xtend and the xtore.
my tap water temperature shows 0 degrees. while my boiler is hot.
First of all, thanks for the great app. However, I do have a question: is it possible, just like in the app, to read out the hours the boiler has been running for central heating and hot water (as a Tag)? And how many cubic meters it has used for that?
