# Ikea TRADFRI spot GU10
**URL:** <https://community.homey.app/t/ikea-tradfri-spot-gu10/22287>\
**Category:** Questions & Help\
**Created:** [December 11, 2019, 6:55am UTC](https://community.homey.app/t/ikea-tradfri-spot-gu10/22287 "2019-12-11T06:55:47Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![BT03](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/bt03/32/18789_2.png) [@BT03](https://community.homey.app/u/BT03)\
**Post date:** [December 11, 2019, 6:55am UTC](https://community.homey.app/t/ikea-tradfri-spot-gu10/22287/1 "2019-12-11T06:55:47Z")
</div>
Hallo,
Iemand hier die mij kan vertellen hoe ik **Ikea Tradfri spots** toevoeg aan mijn Homey app? ik heb ze gevonden in de app, maar bij het connecten gaat het mis… Zoals de app aangeeft heb ik ze uit/aan geschakeld, ook de resett optie gebruikt (6x aan/uit) maar ik krijg geen verbinding…
Mijn vermoeden is dat ik er een afstandsbediening/hub/driver bij moet hebben? Ik had juist gehoopt dat dit niet nodig was…
Iemand die mij verder kan helpen?
Someone here who can tell me how I add Ikea Tradfri spots to my Homey app? I found them in the app, but when connecting it goes wrong … As the app indicates, I switched them off / on, also used the resett option (6x on / off) but I can’t get a connection …
My suspicion is that I need a remote control / hub / driver? I had just hoped that this was not necessary …
Someone who can help me further?
**Author:** ![Jan\_Peeters](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/jan_peeters/32/86660_2.png) [@Jan\_Peeters](https://community.homey.app/u/Jan_Peeters)\
**Post date:** [December 11, 2019, 7:17am UTC](https://community.homey.app/t/ikea-tradfri-spot-gu10/22287/2 "2019-12-11T07:17:59Z")
</div>
> [@BT03](#):
Have you tried this:
> [@Pairing Ikea tradfri problems](https://community.homey.app/t/pairing-ikea-tradfri-problems/4110/24):
> When experiencing problems when adding IKEA devices, this is what worked for me: 0. Keep the device close (\<20cm) to Homey Make sure the device is ON Add device in Homey When screen “add device” appears, turn OFF (2sec), ON (0,5sec), OFF (2sec), ON (0,5sec), OFF (2sec), ON (0,5sec), OFF (2sec), ON (0,5sec), OFF (2sec), ON (0,5sec), OFF (2sec), ON After some 4sec, the device will blink once. The pairing will start. I hope this helps.
